Left rear door handle RRC - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 04-23-2016, 12:12 PM Thread Starter
Quoted: 0 Post(s)
So...I just replaced my exterior left rear door handle, and...it doesn't work. I've looked and looked and I canít figure out where I went wrong. It looks like from diagrams etc., that all you need to do is insert the "elbow pin" into the exterior handle spring loaded lever. Which i have done. When simulate opening the handle the "elbow pin" moves the mechanism that is connected to the rod that runs the inside handle. Note that the inside handle does open the door. The electric locks work in the RRC and the door is unlocked when I try to open from the outside.
The RRC is a 1991 if that matters.
Any help would be appreciated.
Thanks.
NCRRC is offline
post #2 of 3 (permalink) Old 04-27-2016, 03:51 AM
Quoted: 17 Post(s)
There should also be a clip that secures the rod to the handle. I'm not sure, from your post if that clip was present on the replacement handle.
Classic Rovers
203-770-1699
Paul Grant is offline
post #3 of 3 (permalink) Old 09-29-2018, 03:33 PM
Quoted: 0 Post(s)
Talking Problem Resolved
I have been struggling with this same issue and theorized that the issue was that the plastic plunger that moves when the exterior handle is operated had lost some of it pushing power and was slipping on the metal plate that moves the rode that is connected to the mechanism. Installed a small bolt and square nut so that the plastic piece would have something to get a grip on and problem solved. Email me for pic
Matt Herrington is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
rear door latch/handle Benji Discovery Series II 12 07-18-2014 06:26 PM
drivers door lock & rear door handle phosphor Discovery Series II 6 05-27-2013 06:25 PM
RRC Left silver door handle. Great divide front bumper! Mikeydfw Land Rover Parts and Vehicles Wanted 3 02-23-2011 06:25 AM
RRC door handle ckrover II Land Rover Parts and Accessories 1 11-24-2010 03:00 PM
Rear door handle jammed breakscat5 Discovery Series II 8 06-07-2008 06:22 AM
You may post new threads
You may post replies
