Low coolant light - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 10-17-2015, 03:16 AM Thread Starter
1993 range rover lwb - Roman Bronze
ehojefua's Avatar
Quoted: 6 Post(s)
Low coolant light
I haves 1993 range rover LWB. My coolant warning light keeps going off when I'm driving but when I'm idle it doesn't flash at all. I checked my fluid level and it is fine. The temperature needle doesn't move. I checked the wires and they are fine and covered. Other than that I'm lost. Does anyone know what else I should check?
1993 Roman Bronze Range Rover County LWB
ehojefua is offline
post #2 of 6 (permalink) Old 10-17-2015, 06:04 AM
Jagfixer's Avatar
Quoted: 12 Post(s)
Garage
Coolant reservoir cap. The sensor for fluid level my have cracked wires or needs replacing.
Larry K, ASE
2011 LR4 HSE LUX
previous owns: 87 Classic
96 Disco, 96 P38
Jagfixer is offline
post #3 of 6 (permalink) Old 10-21-2015, 01:06 AM
Quoted: 3 Post(s)
Check your fuse as the coolant light is shared with other items. On my 89 if a fuse goes on the cigar lighter the coolant low warning flashes.
Locketundefined
locket is offline
post #4 of 6 (permalink) Old 11-01-2015, 06:44 PM Thread Starter
ehojefua's Avatar
Quoted: 6 Post(s)
I ordered a replacement coolant cap but before The cap arrived, I had the rover cut out on me on the highway. I was driving on I 95 south from the Bronx, ny to New Jersey . 5 miles into the drive the low coolant light started flashing and this time it didn't go out. I kept driving because I knew I filled the coolant just three days prior and also I did not notice any leaks while parked. As soon as I got to the New Jersey border the car just died and came to a stop. I checked the battery power and the alternator and it is fine. I checked the fuel pump and it is also fine. The lights and everything else works. It starts but does not turn over. I also went to the passenger seat, moved it all the way forward and switched the fuel relays position and still nothing. I also looked at the switch ( located under the passenger seat) and made sure it wasn't switched off by accident and it wasn't. I am now at a lost for ideas.
Anyone can chime in anytime, I will be greatly appreciative.
ehojefua is offline
post #5 of 6 (permalink) Old 11-03-2015, 01:22 AM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
I know this idea may seen crazy
But sometimes mine kinda does that
If I have gas cap on to tight
It just dies and won't start
Good luck
mikieman is offline
post #6 of 6 (permalink) Old 11-05-2015, 03:24 AM Thread Starter
ehojefua's Avatar
Quoted: 6 Post(s)
@mikieman: I thought of that and tried that but that didn't solve the problem. The problem was the distributor rotor. That failed...got another one and problem fixed...about the coolant light situation, changed the cap...still need to change the expansion tank to the white one
ehojefua is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Has anyone installed a low coolant sensor on a Disco II? SafariDave Discovery Series II 17 10-14-2018 11:14 PM
Low coolant sensor mbruneaux Discovery Series II 1 12-28-2012 09:51 PM
water pump/ low coolant light Classic4Me Range Rover Classic 11 12-05-2010 07:11 AM
Low coolant level Makithot Range Rover P38, Mk III and Range Rover Sport 0 12-18-2008 10:28 AM
lr3 v6 low coolant problem nessen Discovery 3 / LR3 1 12-08-2008 08:20 AM
You may post new threads
You may post replies
