New calipers now abs pump grinding - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 01-22-2019, 05:31 AM Thread Starter
FlagRover's Avatar
Quoted: 0 Post(s)
I installed 4 new calipers and pads on my 1990 RRC. Followed the 14 crazy steps to bleed the system. Got down to the last of it and the abs pump started to grind. I rebled the system and still the same. If I introduce air into the system, open the bleeder on the pump or master cylinder, it stops. Tighten the bleeder then it starts grinding again...Any ideas?
JP
FlagRover is offline
post #2 of 2 (permalink) Old 01-23-2019, 02:44 PM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
If you are self bleeding your system
Take a piece of vacuum hose that fits on the bleeder screw and take a large bottle of break fluid about half full and have another bottle
Take the half full bottle and attach the vacuum hose to the bleeder screw and the other end into the brake fluid loosen the bleeder screw and pump the brakes
As the airs bleeds from the system it will
Suck up the fluid and keep the air out
Do this starting with the farthest brake
Make sure you keep the brake resavor
Full
And the one at the bleeder screw dosent overflow
Do this at each brake
It works I’ve done this for years
Also check the hose going into your abs pump
If your brake fluid goes all the way down
There is a old gunk that can clog
the intake to the pump
You can check it by opening the bleaker screw by the hose if it running and you open it
It should squirt out fluid
Good luck
im an american i dont speak english
1991 range rover
now parts
92 LSE
mikieman is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
water pump grinding ark Discovery Series I 3 12-16-2016 06:24 PM
Front Passenger Window Regulator Replace Now Grinding Noise rwcmick Discovery Series II 0 06-10-2016 03:11 PM
WABCO ABS pump and near new ABS Accumulator Frank Rorabaugh Land Rover Parts and Accessories 1 08-25-2012 10:23 AM
grinding, popping from rear wheels....what now? BlackSVT Discovery Series II 6 06-21-2010 10:08 AM
ABS/ETC lights are off now ABS is over reacting Sign Guy Range Rover Classic 3 12-15-2006 04:27 PM
You may post new threads
You may post replies
