No Brake Lights - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 02-16-2019, 02:48 PM Thread Starter
FlagRover's Avatar
Quoted: 0 Post(s)
No Brake Lights
My brake lights have all (3) stopped working. All fuses and wiring looks good. Bulbs are good. I've been trying to fix this for days now and cant seem to figure anything out. Ideas?
1990 RRC County
2" OME Lift
2" TODDCO lift
Scorpion Rear Trailing Arms
265/75/16 STT Cooper's Discoverer Muds
Custom Bottorf Fabrication Spare tire carrier.
FlagRover is offline
post #2 of 7 (permalink) Old 02-16-2019, 04:48 PM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
Brake light switch is a simple power in power out (when brakes applied)
Check for power to and if okay power thru.
If no power to check fuses.
Hope that helps.
Let us know how you make out.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 7 (permalink) Old 02-18-2019, 05:09 AM Thread Starter
FlagRover's Avatar
Quoted: 0 Post(s)
So I took the "brake switch" out and tested it. Got no readings. Went to napa and showed them the switch, to which they showed me one that wasn't even close to the 2 prong one with a vacuum line on it that I had in my hand. The local junk yard here has a 90 rrc so I went and pulled it off that one. Came back and installed it and nothing. Traced the wires again, fuses, everything you can think of. Was reading more about brake switches and came across an article that stated that some vehicles have 2, yes 2 switches on the peddle. One for cruise control with a vacuum line on it and another higher up for the lights. Sure enough, theres a second one way above the cruise one 4 prong not 2 and much larger. And sure enough it matched napa. Went and got the one from napa and everything works.
So for those non mechanical folks out there, we have 2 switches!
JP
1990 RRC County
2" OME Lift
2" TODDCO lift
post #4 of 7 (permalink) Old 02-18-2019, 06:49 AM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
Thanks for sharing your fix👍
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #5 of 7 (permalink) Old 02-18-2019, 07:29 AM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
Yes there are two switches
im an american i dont speak english
1991 range rover
now parts
92 LSE
mikieman is offline
post #6 of 7 (permalink) Old 02-18-2019, 09:34 AM Thread Starter
FlagRover's Avatar
Quoted: 0 Post(s)
Well now I know a LOT more about the brake system and wiring
1990 RRC County
2" OME Lift
2" TODDCO lift
post #7 of 7 (permalink) Old 02-22-2019, 09:27 AM
Living it...
MikeShaw's Avatar
Quoted: 1 Post(s)
Garage
I got a Series IIA last year and had the same problem. I was pleased to learn there is 1 brake light switch. I swapped it out, and brake lights worked. Thus began my new life learning all things maintenance and repair of my 1970 Series IIA. Hahaha! This forum is encouraging, so thank you all!
Because life's too short not to drive one.
MikeShaw is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
No warning lights / No ABS - No TC Rover2 Discovery Series II 20 09-04-2010 05:18 AM
Why do my tail lights and dashboard lights only go on when I brake? bodykits Accessories 2 05-27-2009 06:07 PM
lights lights lights disco1667 Discovery Series II 3 10-24-2008 08:56 AM
First no interior lights now no dash lights either hamrendan Range Rover Classic 4 10-12-2004 10:55 AM
Lights! no lights sidawson Discovery Series I 3 09-14-2004 01:47 PM
You may post new threads
You may post replies
