Range Rover Classic V8 3.9EFI Hotwire engine - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 01-30-2019, 04:11 PM Thread Starter
Quoted: 1 Post(s)
When starting the engine it has to crank a long time before firing up, doesnít matter if engine is hot or cold, it will always start and it runs well, no idle issues, no stall issues.
I am tearing my hair out trying to find the fault.
Any suggestions as to what would cause this?
Back ground
NEW Genuine Lucas distributor cap and rotor arm.
NEW NGK BPR6ES spark plugs.
NEW Magencour leads.
NEW Distributor about 4000miles
ECU remapped by Mark Adams
Rovergauge diagnostic system plugged in and no fault codes shown up on the laptop.
Many thanks Ives
Big Ives is offline
post #2 of 6 (permalink) Old 01-30-2019, 05:02 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 111 Post(s)
When I had a long crank issue it turned out to be a fuel pressure issue. New pump and filter put everything right.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 6 (permalink) Old 01-31-2019, 01:59 AM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
At first thought I was thinking timing
But looks like all new
Army probably right about fuel pump and filter
You might also check the vacuum hose
At the fuel pressure regulator
And what year is your Rover
im an american i dont speak english
1991 range rover
now parts
92 LSE
mikieman is offline
post #4 of 6 (permalink) Old 01-31-2019, 03:08 AM Thread Starter
Quoted: 1 Post(s)
Lads thanks for the feed back
the engine is a 1994 RRC unit, rebuilt and in a Defender 90
googling this side of the pond i have read a load of information regarding the cranking issues.
what surprises me when she started she drives without any issues.
will look at the internal fuel pump and the fuel pressure regulator when i get back home in a few weeks from work
i to am thinking fuel related as when she is stopped it appears the fuel drains back to the tank and there is none in the fuel rail to start her again????.
in fact i cut the fuel hose and placed a non return valve in line, took her for a run but the engine didn't like that idea and i had to remove it after only a few miles and replace the complete hose..................................cheers Ivan
Big Ives is offline
post #5 of 6 (permalink) Old 01-31-2019, 05:00 AM
p76rangie's Avatar
Quoted: 386 Post(s)
Try turning the ignition on for a few seconds, then off again and then on for a few seconds and then off again before trying to start. This will run the fuel pump and build up fuel pressure. If it starts quicker doing this, then it could be the fuel delivery system.
I have found that the motor like to be spun over quickly to start easily. So you might have a problem with your battery, starter, wiring, etc.
As others have recommended, you should check your timing. The more advanced the timing the easier it will start.
p76rangie is offline
post #6 of 6 (permalink) Old 01-31-2019, 04:07 PM Thread Starter
Quoted: 1 Post(s)
wee update
@p76rangie, will try what you suggested about switching on off on off and see
new battery just installed a few months ago, wiring all good to starter and everywhere else.
i plan to check the timing when i get home, as i didn't check this before, but no pinking when i gun her, no lag when i press the pedal, very torquey.......................cheers Ivan
Big Ives is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Lucas hotwire fuel injection diagnostic system for sale- complete unit + memory cards ROVERSALES Land Rover Parts and Accessories 0 11-06-2012 09:48 PM
Range Rover Classic V8 Exhaust video ehojefua Range Rover Classic 26 12-06-2009 05:07 AM
Hotwire? ronpopeil7 Range Rover Classic 0 10-01-2009 05:44 AM
Ignition problems with my 90 3.9efi ninetyv8 Hybrid 3 01-24-2009 12:27 PM
Ignition Problems on 3.9 V8 EFI hotwire ninetyv8 New Member Introductions 0 12-30-2008 02:41 AM
You may post new threads
You may post replies
