LR4 Clacking Noise Diagnosis not chain - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 03-03-2019, 06:09 PM Thread Starter
Quoted: 1 Post(s)
2011 LR4 HSE 115k miles with a new noise after a really cold start. Recently had chain and tensioners replaced, confident it isn't that.
Leaning towards it being the fan clutch based on some searches. I'll get a video uploaded of my own engine. But until then if you search "2011 LR4 5.0 ticking knocking cold noise" on youtube there is a post with the exact same noise.
The clicking does not increase with RPMs, very consistent noise, pretty rythmic clack, almost sounds like a clock ticking. 1 of the video comments suggested Fan Clutch.
I've also read that the fuel pumps can be noisy, but since they're cam following and this noise does not follow RPMs I doubt it's the pumps.
Anyone else think that it's the fan clutch? Any other testing I can do to check it out? Appreciate the help, Thanks!
John Fischer is offline
post #2 of 7 (permalink) Old 03-03-2019, 06:59 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 106 Post(s)
Cold temps and a odd noise is usually the hi pressure fuel pump making noise. If it goes away when the temp goes up it is most likely your culprit
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 7 (permalink) Old 03-04-2019, 04:17 AM
member
SafariDave's Avatar
Quoted: 132 Post(s)
At what milage did you do your timing chain tensioners. Is it true that 2013 models had the tensioners replaced by LR? If its the Fan Clutch I would just change it ASAP.
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #4 of 7 (permalink) Old 03-04-2019, 06:03 AM Thread Starter
Quoted: 1 Post(s)
Well it did go away with an increase in temperature. Garaged the truck last night, no noises on the morning commute. However sitting outside at 15 degrees F, all day today, might bring it back.
If it is the Fuel pump though, shouldn't the ticking be tied to engine RPMs? It is very rhythmic and consistent.
Dave
SafariDave, chain tensioners were done at an independent shop at 114k miles. Basically last month, I've only put 1k miles on it since then. If it's the Fan Clutch I am worried. I felt no wobble in the fan last night. And it's gone away now that the car didn't sit outside in below 0 temps.
post #5 of 7 (permalink) Old 03-04-2019, 06:30 AM
ArmyRover's Avatar
Quoted: 106 Post(s)
Not really the high pressure pump is a just a booster as I understand it so it runs at a pretty set clip.
1972 MGB
post #6 of 7 (permalink) Old 03-04-2019, 06:39 AM
member
SafariDave's Avatar
Quoted: 132 Post(s)
Take it back to the shop that did the tensioners to have it diagnosed that its not the tensioners.
I like the LR4 and still interested in owning one, but the expensive tensioner issue, the water pump issue, plus the diffs, it seems like just too many things go wrong compared to the LR3.
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #7 of 7 (permalink) Old 03-04-2019, 07:27 AM Thread Starter
Quoted: 1 Post(s)
Hmm,
I'm confident it isn't the chain tensioner, guides, or chain itself.
I'm very torn between whether it could be a fuel pump or the viscous fan clutch. No other ideas beyond this. If it comes back tonight after sitting cold all day I will get a video.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Land Rover 4 / LR4
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Diagnosis: Howling Noise from Engine Pastiche3 Discovery Series II 2 02-20-2014 06:01 AM
New Noise - Clacking, clicking, rotational noise front end NYChaze Discovery Series II 2 08-21-2013 07:33 PM
Loud "clacking" at start up... anbran Discovery Series II 1 07-13-2012 05:35 AM
Weird Noise Clacking when doors open alan944 Discovery Series II 8 06-01-2010 10:08 AM
not about the car just the chain Cdawg09 General Land Rover Discussion 1 03-08-2006 06:38 AM
You may post new threads
You may post replies
