Aftermarket wheels - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 08-28-2009, 12:35 PM Thread Starter
discorover1's Avatar
Quoted: 0 Post(s)
Aftermarket wheels
Just any FYI for anyone looking for a set of aluminum wheels for there D1.
Wheel Finder - Truck & Jeep Wheels, Off Road Wheels, Cast & Steel Wheels on 6.5&cio=False&df=0&dt=0&finish=0&cons=0&ab=False&p g=1&SortBy=DisplayPrice&SortDir=asc
I found several sets of wheels for only $50.00 each. They will need a little work before they will fit. I purchased mine and they look great on my Disco....
If you need to get lugs, just go to Stockton Wheel Service - Custome Wheels. they sell 16mm x 1.5 lugs.... Nothing wrong with the stock wheels, but something different is not so bad from time to time....
ID:	22179   Click image for larger version
discorover1 is offline
post #2 of 4 (permalink) Old 09-11-2009, 12:58 PM
baseballrover's Avatar
Quoted: 0 Post(s)
What is "a little work"?
baseballrover is offline
post #3 of 4 (permalink) Old 09-16-2009, 08:35 AM Thread Starter
Quoted: 0 Post(s)
Little Work
The wheels would not slide up all the way onto the lug studs.... Bolt pattern is perfect and centered perfect... Just the studs would curl up the aluminum if you were to force the wheel on... So I had to drill out the lug holes from the back side of the wheel... just open them up a fraction. So wheels would slide all the way on... Everything else was perfect... Just the lug holes are not large enough... Im talking 1/8 of an inch or less....
post #4 of 4 (permalink) Old 09-17-2009, 12:06 PM
Quoted: 0 Post(s)
Ok thanks
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 04:47 PM
Aftermarket Wheels? mkri23 Discovery Series II 5 01-28-2009 08:27 PM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 05:33 PM
Aftermarket wheels DiscoTex Wheels and Tires 14 11-11-2005 05:49 AM
Range Rover/Disco II 18" Mondial Wheels K Kelly Land Rover Parts and Accessories 1 01-07-2005 06:56 AM
You may post new threads
You may post replies
