Mass Airflow Sensor Alt - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 05-24-2019, 06:40 PM Thread Starter
Quoted: 1 Post(s)
Greetings all!
I have a question that I hope someone may know. I am currently putting my engine back together after replacing head gaskets and valve cleaning. My engine is a Gem V8 4.0 and what I was wondering is since my MAF is stock and old, would anyone know if there may be an alternative sensor that I could use or a site that sells the sensor more cost effectively?
Thank you all and looking forward to your wisdom ^_^.
roverfox9 is offline
post #2 of 8 (permalink) Old 05-25-2019, 05:09 AM
sierrafery's Avatar
Quoted: 246 Post(s)
The MAF sensor for petrol V8 engine engine is too important to mess with cheap aftermarket alternatives as the whole fuelling stoichiometric calculations are based on it's inputs... better bite the bullet and buy genuine or take the risk to have driveabiity issues, your choice, google out ERR5595 and choose what you want
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 8 (permalink) Old 06-04-2019, 07:11 PM Thread Starter
Quoted: 1 Post(s)
Ouch!
Well then I shall see on google or Atlantic British (good stuff they got )
Thank you for your input. I seriously think my high idle issue is due to the MAF. My engine screams up to 2000 rpms when started, then drops down to fairly normal rpms when I put it in D or R. Now when I spray cleaner in the MAF the idling is pretty much normal. Hence my curiosity about any alternatives and such.
post #4 of 8 (permalink) Old 06-05-2019, 01:49 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 10 Post(s)
Like Fery said you don't want to go cheap on a MAF sensor.
For a great Disco 2 Bosch made MAF runs about $65-$80 so I don't know what a Disco 1 MAF for a GEMS would run you.
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, SAI modded K&N filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #5 of 8 (permalink) Old 06-05-2019, 03:43 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Here's a OE spec https://www.motorcarsltd.com/err5595.html
might be a bit more https://www.amazon.com/Bosch-Origina.../dp/B006K92N1E
post #6 of 8 (permalink) Old 06-05-2019, 12:05 PM
tyl604's Avatar
Quoted: 179 Post(s)
Hate to ask a silly question, but did you have the heads checked for warping before replacing the gaskets? This week another poster in a new thread did not and suffered another blown head gasket.
tyl604 is offline
post #7 of 8 (permalink) Old 06-06-2019, 01:47 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 10 Post(s)
Originally Posted by sierrafery View Post
That's crazy money!!!! Prices have definitely gone up since I bought mine a year ago.
@roverfox9 ... Try RockAuto for your Disco 1.
MIKE
JUKE179r is offline
post #8 of 8 (permalink) Old 06-06-2019, 06:51 PM Thread Starter
Quoted: 1 Post(s)
We used a straight edge to check the heads. It looked good, so did the cylinders. I believe I am ok, when my pops and I took it apart we found alot of bolts that where loose as if they where hand tightened (not headbolts of course.)
And thank you @JUKE179r for your recommendation.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
fault code 50 secondary airflow bank 1 bazza1 Discovery Series II 1 08-23-2016 04:35 AM
mass airflow sensor empeluso Range Rover Classic 6 05-19-2010 09:10 PM
RR D1 Parts 150 Amp Alt /Half Shafts/ CVs / Pumpkin/ more!! hamrendan Land Rover Parts and Accessories 1 07-25-2006 05:49 PM
bosh airflow meter settings/distributor pick up coil Najam uz zaman Range Rover Classic 2 01-01-2006 09:27 PM
Mass Airflow Sensor PICKLE Discovery Series I 9 11-03-2004 06:00 PM
You may post new threads
You may post replies
