no electrical power - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 04-05-2019, 05:49 AM Thread Starter
Quoted: 1 Post(s)
no electrical power
The rig is a 1998 disco I with 130k miles.
I hadn't driven it in 2 months, it would not crank. Charged the battery overnight, still no crank. Removed and tested starter, confirmed it was bad. Replaced starter, now I have no electrical power anywhere. Thinking it was the battery cables, both have been replaced, battery was also load tested, fuses were visually checked and look good. Main ground wires were cleaned and tightened. Could a faulty alternator cause a total loss of power? What am I missing? Any ideas?
Thanks in advance for any ideas.
Powwow is offline
post #2 of 10 (permalink) Old 04-05-2019, 11:20 AM
sierrafery's Avatar
Quoted: 246 Post(s)
OK you charged the battery over night but did you measure the voltage on it while switching on to crank? ...if not do that cos old batteries once dead charging them is futile cos they'll not gain power again...also simply measuring voltage on it unloaded is irrelevant cos even if you see 12V it will drop to nothing under load
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is online now
post #3 of 10 (permalink) Old 04-05-2019, 04:53 PM Thread Starter
Quoted: 1 Post(s)
The battery was load tested. Unable to check voltage when cranking, no electrical power anywhere. Thanks for your input.
Powwow is offline
post #4 of 10 (permalink) Old 04-05-2019, 11:51 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I can't understand why you are unable to check voltage while cranking, ask somebody to turn on the ignition and measure on the battery cos if it's some short circuit the voltage drops even if the battery was tested... if no voltage drop on the battery measure on maxi fuse MF1 (100A) in the engine bay fusebox and if you have voltage there and nowhere else replace the fusebox
post #5 of 10 (permalink) Old 04-06-2019, 07:56 AM Thread Starter
Quoted: 1 Post(s)
Sorry, I misunderstood your reply. I cycled the key to the start position while monitoring battery voltage, it registered 12.5 volts while in the off position as well as with the key in the crank position. The master fuse registered zero volts in either position.
Thanks again
Powwow is offline
post #6 of 10 (permalink) Old 04-07-2019, 04:54 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Then if the main battery lead is well connected to the fusebox better get a good one cos it seems that it's an interruption in there as the battery is hardwired to the fusebox and that fusible link should have power, see the diagram
Name:	D1 main feed.jpg
post #7 of 10 (permalink) Old 04-07-2019, 07:05 AM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Main junction is the positive post on the starter.
I would check it again
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #8 of 10 (permalink) Old 04-10-2019, 10:00 AM Thread Starter
Quoted: 1 Post(s)
Sierrafery, do you have a wiring diagram for the gas 4.0?
thanks
Powwow is offline
post #9 of 10 (permalink) Old 04-10-2019, 11:26 AM
sierrafery's Avatar
Quoted: 246 Post(s)
thanks
All the diagrams are in the following document https://www.sugarsync.com/pf/D8700125_05791262_28935
post #10 of 10 (permalink) Old 04-10-2019, 01:04 PM Thread Starter
Quoted: 1 Post(s)
Thank you Sierrafery!
Powwow is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
No electrical power srdvs1962 Land Rover 4 / LR4 7 02-28-2019 08:57 PM
power seat no power??? cedarjames Discovery Series II 2 09-22-2011 04:54 PM
87 range rover no electrical power - please help PA Rovers Range Rover Classic 1 03-06-2011 09:56 PM
No start, No power to fuel pump, ECU? Tiderover General Land Rover Discussion 2 09-17-2005 01:24 PM
You may post new threads
You may post replies
