No spark from coil - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 1 (permalink) Old 05-23-2019, 08:02 AM Thread Starter
donno's Avatar
Quoted: 0 Post(s)
No spark from coil
95 Disco Standard
Any thoughts on no spark from the coil?
Seemed to happen intermittently and now won't start at all and have traced it to no spark. Been following the Rave troubleshooting and I've done the 4 voltages at the coil and they seem good. For test 3, amplifier switching, I'm getting 12 volts with the ignition off where it says it should be zero. I seem to remember that this test was an error in Rave manual so not sure on that? Can anyone confirm proper procedure?
I have already fitted new coil and amplifier. New wires, cap and rotor. Pickup in the distributor seems to have the correct resistance (3.5k ohms). I'm going to check the air gap and check the continuity of all the wires including the relocation wire for the amp. Anything else I can check?
Cheers
donno is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
95 Rover Classic 4.2 no spark at coil kiwii5858 Range Rover Classic 8 05-28-2012 08:46 AM
Help disco died today, no fuel pressure, no spark?? addam Discovery Series I 14 03-10-2012 06:45 PM
2003 Disco II No Spark, No Fuel, but cranks Jester01 Discovery Series II 3 05-02-2011 07:50 PM
no start will no spark. killthimall Discovery Series I 6 08-18-2009 07:49 AM
No Spark from Coil - Please help! mahi 1 Range Rover Classic 4 09-24-2008 08:03 AM
You may post new threads
You may post replies
