OBD Scanner - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 15 (permalink) Old 12-01-2010, 08:53 AM Thread Starter
Quoted: 0 Post(s)
OBD Scanner
Tired of going to the mechanic everytime check engine light comes on. Which scanner should I buy? Where does it plug in and is the connector universal? And how do I read the codes - does it say right on the screen what the code is? Or do I have to look it up in a glossary? Thanks guys.
crowe938 is offline
post #2 of 15 (permalink) Old 12-01-2010, 10:25 AM
Quoted: 0 Post(s)
obd
just had the local Autozone put their reader on my disco I. Connector is right under the steering column. Gave a readout that said ignition failure/misfire. Don't know what brand of reader they use but they don't charge anything for doing it.
bondsman is offline
post #3 of 15 (permalink) Old 12-01-2010, 10:37 AM Thread Starter
Quoted: 0 Post(s)
I think I'd like to have one in case I'm not near a store. Then I could just check myself and not have to deal with sales people.
crowe938 is offline
post #4 of 15 (permalink) Old 12-01-2010, 10:49 AM
rmuller's Avatar
Quoted: 2 Post(s)
If it's an ODB-2 compliant truck, this one will work fine:
Amazon.com: Autel MaxiScan MS300 CAN OBD-II Scan Tool: Automotive Amazon.com: Autel MaxiScan MS300 CAN OBD-II Scan Tool: Automotive
It's cheap and does the job -- It'll give you the code number and clear the codes.. Just keep a book of codes, or have a computer/smartphone nearby where you can google it... it's similar to what I use and works fine.
Ryan ::
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
rmuller is offline
post #5 of 15 (permalink) Old 12-01-2010, 10:57 AM Thread Starter
Quoted: 0 Post(s)
crowe938 is offline
post #6 of 15 (permalink) Old 12-01-2010, 12:28 PM
member
lambo's Avatar
Quoted: 0 Post(s)
Garage
i got the actron pocketscan plus at Advance Auto and it works great. its a reader/eraser, 50$ on sale and this is a link to your codes,print it off and youll always have them.. Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
'98 Disco I LE, 4.0 ,auto, 130k, 3"RTE lift, 265/75/16 ,RTE frt bumper,10k winch, digi camo headliner, and HMans approval
lambo is offline
post #7 of 15 (permalink) Old 12-02-2010, 06:54 PM
amfoto1's Avatar
Quoted: 0 Post(s)
I keep an OBD II reader in my glove box and use it to clear the code and turn off the "check engine" light every few weeks when it comes on. It's always a "rough road" fault, related to one of the ABS sensors. I've disabled the ABS anyway, so I just clear the code.
I suppose I shouldn't say "always". At least once I got another code, related to a rough running engine due to the MAF needing cleaning.
I've gotten to the point where I can hook up the OBD and clear a code while driving. It's pretty easy.
Most faults have to happen and be detected something like 40 times before they set a code and turn on the "check engine" light. If that light comes on steady, it's a minor code. If it flashes it's something more critical.
And those cheap OBD units aren't like the full computer diagnostics that a mechanic can run... Those can detect faults as they occur and give much more precise info about what's wrong. Unfortunately, those computer based diagnostic programs are damned pricey.
Alan Myers
San Jose, Calif.
'97 Disco SE7 (since '99)
Arctic White, OME, Bilstiens,
Hellas, LR A-Bar, head & tail
lamp guards, misc. other mods.
amfoto1 is offline
post #8 of 15 (permalink) Old 12-03-2010, 06:04 AM Thread Starter
Quoted: 0 Post(s)
How do I run the scan? Car in 'on' position? Motor running?
crowe938 is offline
post #9 of 15 (permalink) Old 12-03-2010, 06:11 AM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Attach cable, key in position 2, push button.
The key is, you may have to take the codes and determine what they mean...as you get a set of letters and numbers and the combination of them can mean different things. Once you get the hang of it it gets easier...there is a list of the codes and their potential meanings. Or you post them here and we get to banter about the meanings at nausea..LOL! It's pretty easy really
DiscoDream2 is offline
post #10 of 15 (permalink) Old 12-03-2010, 07:22 AM Thread Starter
Quoted: 0 Post(s)
Got it. Bought a scanner that will tell me what the codes are - but, I'll be coming to you guys for advice on the remedies!
crowe938 is offline
post #11 of 15 (permalink) Old 09-20-2012, 08:50 PM
Quoted: 0 Post(s)
ODB2 scanners
I have seen some excellent systems but cannot find one that will read Landrover ABS codes? Normally they restrict to domestic, Honda & Toyota. Any recommendations?
Pat Duffy - D2 owner & also a "Thai" Triumph Bonny. In UK had 1x 1961 S2A, 1 x1993 Disco, 2xLR90s 1x'95 RangeRover & 1xLR110 with Airlockers etc
wyomingpat is offline
post #12 of 15 (permalink) Old 12-20-2012, 12:56 PM
Quoted: 0 Post(s)
Just Bought this one!
Hi I just bought this for my 2005 LR3 and I hope it works. I want to know if there is a website for a book of codes. Please let me know if you any info about that. Thanks.
Mike B is offline
post #13 of 15 (permalink) Old 02-11-2019, 09:50 AM
Lord_Peter's Avatar
Quoted: 2 Post(s)
Garage
Amazon.com: Autel MaxiScan MS300 CAN OBD-II Scan Tool: Automotive[/url]
I have one of these and it gives "Link Error" when connecting to my Range Rover... am i missing a step?
works just fine on my Wifes Dodge and Daughters Chevy.
Ex Pat Veteran
Ranger Rover Owner and all round IT Nerd.
Lord_Peter is offline
post #14 of 15 (permalink) Old 02-11-2019, 09:55 AM
rmuller's Avatar
Quoted: 2 Post(s)
Not sure about the Range Rover... I've had similar OBD readers work fine on Discovery and LR3s... I've had one truck in the past though that had some fault with the OBD port though.
Ryan ::
rmuller is offline
post #15 of 15 (permalink) Old 02-11-2019, 09:57 AM
Lord_Peter's Avatar
Quoted: 2 Post(s)
Garage
Hmmm. AutoZone's Scanner works and so does the indy dealer who sold me the RR.
Wonder if my scanner is lacking a firmware update or something?
Ex Pat Veteran
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
OBD & 3 Amigos scanner recommendations Discobob Discovery Series II 14 01-04-2011 03:38 PM
Dumb OBD scanner question jfry75 Discovery Series II 3 05-16-2010 02:12 PM
Scanner? tmac6197 Accessories 1 04-20-2010 04:04 AM
scanner roverich Discovery Series I 4 06-24-2009 02:17 PM
OBD Scanner Issues malamute Discovery Series II 16 06-21-2007 06:14 PM
You may post new threads
You may post replies
