What size tire can i fit without rubbing? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 11-20-2018, 08:57 PM Thread Starter
Quoted: 1 Post(s)
I've just purchased a 3-inch lift kit for my 98 disco 1! i was wondering what size tire will i be able to run with minimal cutting of the fender. I'm looking for the max size and anything else that may be of use!
thanks in advance to your support.
K1LRD1 is offline
post #2 of 5 (permalink) Old 11-21-2018, 03:07 AM
p76rangie's Avatar
Quoted: 385 Post(s)
Research a "Camel Cut" named after what they did to the vehicles in the Camel Trophy https://landroverforums.com/forum/di...mel-cut-39163/
You need to trim back the last few inches of the rear wheel arches.
If you have a standard front bumper, it may also need to be trimmed a little.
p76rangie is offline
post #3 of 5 (permalink) Old 11-21-2018, 02:14 PM
Quoted: 9 Post(s)
After making cuts and refolding over a hard wood buck cut to the new desired arch radius I would add an aluminum backup bar, installed it behind those cuts then Tig those cuts to the bar, (bar makes for perfect backup when welding also closing up those open pie cuts. Way stronger than leaving the fender roll cuts open as you'll end up with growing metal fatigue cracks. Prep, prime and repaint as your already there, the cheap price you'll pay for doing body modifications.
Personally I would of gone higher up the fender arch to avoid the shallow angle change at the transition from the factory arch radius to your fender modification plus kept and followed that continuous wheel arch radius vs a transition from radius to straight line. Aluminum is so much softer and easier to work with than steel bodied vehicles JMO.
.....~~=o&o>......
BierNut is offline
post #4 of 5 (permalink) Old 11-23-2018, 03:54 PM
Quoted: 0 Post(s)
I think the best thing to do here is to take your car to the workshop so they can find the tire size and specifications that will match your car.
Sellatease is offline
post #5 of 5 (permalink) Old 11-23-2018, 11:22 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Unfortunatey the pics are missing but you can make and ideea from the text here https://www.landyzone.co.uk/land-rov...-wheels.67858/
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2002 without CDL. Can I drive without front shaft? tomcrom Discovery Series II 1 02-01-2016 02:57 PM
spare tire gas can holder and tire size 2003discoII Discovery Series II 0 10-01-2010 04:51 PM
Max Tire Size - Without Lift rwmdisco Discovery Series II 9 03-14-2010 05:12 PM
biggest size tyre without rubbing? Amclutch Range Rover Classic 6 03-12-2010 09:23 PM
Whats the biggest tire without rubbing? blackls Wheels and Tires 3 01-15-2009 07:25 PM
You may post new threads
You may post replies
