1 - 2 of 2 Posts
Hi,
My disco would take 3 tries to start up and finally gave up starting. I replaced the fuel pump and it still does not start. I put in a new battery as well and it will still not start. Anybody have any suggestions? Thanks in advance.
· Premium Member
Any codes/CEL? The crank position sensor is a common cause of no starts for the D2. I would say check your inertia switch too, but if it was eventually starting before it's probably not that (you would have the hazards coming on as well if it was the IS)
1 - 2 of 2 Posts
