1 - 2 of 2 Posts
I have a 2006 Range Rover SC. When I try to turn her over nothing happens. No click no noise just silence. The AC turns off when I turn key and that is it. Lights all turned on radio on... still tried jumping with no luck. Drove her all day as recent as 4 hours earlier with no problems. No over heating.
Any thoughts of wisdom?
Starter relay ? If the starter is not cranking when you turn the key - if check voltage at starter motor. If it is getting 12v there - then starter motor itself is probably dead. If no voltage there when you crank - remove and test relay - if that works then there is another issue with ignition switch itself or a anti theft etc.
1 - 2 of 2 Posts
