1 - 3 of 3 Posts
I was looking into getting these spacers for my 2000 Discovery II. Since I have the RR 19" wheels I was looking for a bit of a lift to make up for the larger rim and tire. I was wondering if anyone has used these on a DII with ACE? Any advice would be great.
· Wheeler
Depends on what you are looking for performance-wise. Funny just answered this question for someone else. You won't get any add'l off-road performance from running 1" spacers w/ stock suspension. Not sure what effect, if any, this will have on your ACE. You'll be able to run (slightly) larger tires but you are probably better off w/ some trimming -or- upgrading the suspension system to OME, Bilstein, or some combination thereof. If you are running stock bumpers you should get a solid 2" out of OME springs. Some like OME shocks, others feel they are too soft. Depends on what you like & what type of terrain you drive.
I was thinking of going with these because I replaced my 18's with the Range Rover 19's and there's some rubbing on tight turns. I don't want to run 255/50 19's because I think it may make the ride a bit rougher. I'd like to stick with the 255/225. I also want to be able to take it off road still. I guess I wanted something to create a small lift w/o redoing the entire suspension.
1 - 3 of 3 Posts
