1 - 4 of 4 Posts
114:Shuttle Valve Electric Failure - after option B
I've checked my work twice and it bench tests perfect. Any ideas?
-----ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
Logged Faults:
<-END Faults
..--Previous Faults--->
Active Faults:
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
· Computer Nerd
did you use the trailer connector? I did on the first one I did, and I'd still get intermittent SVS faults. I think some of them don't make very good connections. The next time I did it, I just used a wire tap and no issues.
That's what I'm thinking. I will hard wire in the fix. Thanks for the feed back.
Discussion Starter · #4 ·
So, After the 3rd time of taking it apart and re-soldering connections and replacing the trailer connector with wire it's fixed. I must not have had a good solder joint.
1 - 4 of 4 Posts
