1 - 14 of 14 Posts
Why 10", what size tire are you going to run?
I believe it won't work, you will rub.
Mike J.
If you are really set on 10"ers, get in touch with Tina at Trek, I believe she sells a black 10".
Mike J.
Discussion Starter · #5 ·
There are some on Epay that I was interested in. I don't think I will get them because they are too wide. I think I will look into some 8 or 7's. I would like to go with that rugged steel wheel with MTR's.
FrankyRizzo said:
Would these cause any problems?
I have a 2 inch lift now. Just wondering if they will rub at all.
Frank,
Sounds like you are going more for looks then function, could be wrong.
Do you have a D1 or DII?
8" is usually considered normal for up to a 285 tire.
You mentioned the MTR's, might want to look at BFG MT's, they will last longer both on and off the road.
Mike J.
Discussion Starter · #8 ·
I would like function don't get me wrong. I just like rugged look of the Nato chunky style wheel and tire. I do think 10" is too wide.
I think I will get the MT's because they will last longer. My D1 is not a daily driver so I am not concerned with noise or road handling.
Good choice, and by the way, the BFG MT's are pretty quiet also.
Mike J.
Magicly Delicious
Mike, if i went with Trek, do you know if i could get them without the 'simulated' beadlock?
1 - 14 of 14 Posts
