1 - 1 of 1 Posts
Discussion Starter #1
1993 Range Rover Classic SWB ‘County Sport’ Edition – Agean Blue
Link to Auction - HERE
Now live on Second Daily Auctions is this 1993 Range Rover Classic County SWB, 1 of 200 “County Sport” editions. It is finished in the rarely seen Agean Blue over Westminster Gray leather. The seller is a self-reported lifelong Land Rover enthusiast who has made this Range Rover a documented ‘restoration’ project over the last couple years. He indicated he has decided to part with this Range Rover to make room for a D110. This RRC presents in original condition and will ship from Washington with a clean clear title in the seller’s name. Please note that the seller does have a rather extensive list of spare parts either for private sale post-auction close or if bidding exceeds $3000 over the reserve, seller will include everything (e.g. OEM Range Rover plastic fog light shields, Yakima rack, replacement front quarter panel, extra upper tailgate, misc. mechanical parts, etc.).
Year: 1993
Make: Land Rover
Model: Range Rover Classic SWB
Mileage: 186k miles
Engine: 3.9L V8
Transmission: Auto
Drivetrain: 4WD
Ext. Color: Agean Blue
Int. Color: Westminster Grey
Key Features: rare County Sport edition, original clean example, only light surface front floor pan rust
Overall, this Range Rover presents very well, save a few bumps and dents and scratches seen on the body. The top clear coat is peeling as seen in the pictures. We note some small panel damage to the front passenger fender, rear driver’s side quarter, and lower rear tailgate. Some minor rust spots are seen on the upper rear tailgate which is a common issue to these trucks. We do not see any rust on the frame, door arches, or bulkhead area and it is reported to have been a west coast car. The previous owner described a low-speed parking lot collision resulting in front passenger side fender damage. Visible in the pictures is a crack in the windscreen.
Inside the leather shows some wear on the driver seat and arm rest. The carpets present clean, and the headliner has been recently refinished. The dash is complete and shows minor warping but in overall very good condition relative to most hard dashes we see. All the knobs and switches look to be in place, as does the original radio which is quite rare to see (the seller does note the controls can be finicky at times). We do not note any offending wood delamination that is usually typical. The seller in full transparency noted that the previous owner was a smoker but is certain has not been smoked in at least three years. The seller has had the RRC thoroughly detailed and has removed any traces of smell. The sunroof works and drains were checked/cleaned during the headliner refinish. The interior lights reportedly work. We note this one has the OEM rubber mats front and rear, and the rear carpet in the load area looks to be intact.
Known work needed or non-functioning features include:
• Driver’s side door speakers do not work
• CD changer does not work
• New hardware needed for passenger side rear lamp guard
• Front footwell surface rust
• Clunk when shifting into Park/Reverse (Personally we’ve never known an RRC that didn’t do this so thanks Seller for noting it)
• Swivel service needed
• Heated seats inoperable
• Side view mirrors do not adjust
• Cruise control inoperable
• Air conditioning needs recharge
• Heated windscreen inoperable
• Windscreen cracked
• Driver’s seat does not move forward or backwards but does tilt.
Known modifications by previous owner include
Air suspension system replaced with factory coils and Bilstein shocks
Aftermarket mechanical oil pressure gauge installed
Replacement engine, including new belts and reconditioned radiator – documented
The winning buyer will receive a list detailing all parts installed, services done, and maintenance performed by current owner showing date and mileage at which service was done as well as a paper file containing receipts and service records.
Modifications and work done by current owner include:
• Oil changes every 3,000 miles with high-zinc 20W50 oil
• New spark plugs (Champion copper)
• New wires (Kingsbourne 8mm)
• New air filter
• Clean idle air control valve
• Throttle cable replaced
• New ignition amplifier module
• Pertronix Flamethrower distributor and cap, OEM rotor
• New cat-back exhaust
• Fuel filter
• Fuel filler cap
• Coolant flush
• Coolant reservoir upgrade
• New temperature sending sensor
• Brake bleed, new brake fluid
• New front brake pads
• New rear rotors (slotted, drilled)
• New rear brake pads
• New front driver’s side ABS sensor
• Repaired binnacle illumination
• Repaired door courtesy lights and replaced timer
• New wiper fluid sensor
• New ignition coil (Lucas)
• Converted fusible links to Discovery 1 fuse block – significant improvement in reliability and serviceability
• New battery
• New battery cables
• New alternator
• New tires (all 5): General Grabber AT-2 in 225/75/16
• Driver’s side front hub and both rear hubs serviced
• New lower steering shaft
• Bilstein steering damper
• Serviced transfer case shifter
• Replaced fluids in both differentials, transmission, and transfer case
• Greased drive shafts every oil change
• New vehicle speed sensor
• New upper tailgate struts
• Repaired door latches
• Discovery 2 door seals (reduce wind noise, better seal)
• Refinished headliner
• Replaced factory fog lamps with Hella aftermarket fog lamps
• New brass radiator plug
91700
91701
91702
91703
91704
91705
91706
91707
91708
91709
1 - 1 of 1 Posts
