I have research the forum, but did not found a solution how to turn SRS light off on 1995 County Classic I just bought, in order to pass Colorado emission test.
I will try to fix it properly but in the mean time need temp fix. Pull the # 11 fuse out, the light stays on no blinking.
Took the instrument cluster out to find the bulb...unless is behind the printed circuit, did not find it.
Went under the drivers seat. There is a blue connector going nowhere?
This is truck is new to me, lots of learning.
Any ideas?
Thank you very much.
Any ideas?
