Yes, ask the above questions, but if this is your first Rover, then I would have it checked out by an independant Rover Shop. You should be able to find one in your area. Most likely if you have a "favorite" mechanic, he will not be able to adequately inspect it. The indepantdants can run a diagnotic on the whole truck for under $100.00. This will test all of the sensors and tell you alot of info. Money well spent if you ask me. If you are your own mechanic, read up on this forum, about everything! Learn as much as you can. :wave:
