I just purchased a 1999 Disco II knowing that it had transmission problems. The previous owner had a fender bender, but drove it home, let it sit for 6 months and then it would not go into drive. I thought that it may have leaked out the transmission fluid and it was just low, but I topped it off and it is a no go. I get a PO722 error code which is a 'Output Shaft Speed Sensor Circuit No Signal'. It goes into reverse fine, but no forward gears. I am used to GM, Ford, and Chrysler transmissions which usually have no reverse when the tranny is blown. I am not really familiar with a BMW transmission, so I was looking for some opinions if it is blown, or if there might be an electrical issue.
Thank you everyone, my first post! :wave:
