1 - 3 of 3 Posts
Ok people, I have an 89 RR that has a 2 amp power drain on the fuel injection system. I pull the relay and the draw goes away. The EFI light illuminates halfway sometimes, sometimes it becomes bright. (Yes weird) sometimes it doesn't come on at all. When I drive down the road the truck will die then pick back up again. I am assuming this is all fuel injection problems. Symptoms all point to this. My major question is how the hell do I track this down!? Again I am assuming it is either a broken wire that is grounding out or a bad ground all together. Any help will be appreciated! :wave:
Short to ground. No easy way track it down. It could take five min or five days. I would start at the ground and work my way back.
Thanks! I will check there first. Yeah is going to be a bitch to find! :help
1 - 3 of 3 Posts
