1 - 20 of 333 Posts
Discussion Starter #1
Hello.. I just re-inherited a 2000 Discovery II that I bought for my GF a few years back... She wanted something new!! Well I decided to transform it into my new rolling tackle box and have started doing all the research for the start of this new project... Everything has been pretty straight forward except one part... I am trying to decide 2 or 3 inch.. lift. I won’t be doing any serious wheeling, but I do find myself in need of a good trail rig from time to time in search of fish!! Well my ?? Is this... I would rather have the 3 inch but have read that the 2 inch lift is the magic number that once you pass you open up a can of pain in the butt... What exactly would I have to change to do the 3 inch? Lift... I like the look and performance of a higher lifted vehicle but don’t want a bunch of hassle... I want to lift it and forget it...if the 3 inch lift is not to bad I would rather go with that... :dunno:
a 3" lift is about $1500 or so if you go rovertym. i'd do it. the performance over a 2" in very noticeable. most people swap to 3" down the line anyways.
you just need the shocks, springs, retainers, brakeline and abs extensions and lower front shock mounts. you can either remove the front crossmember, or get the spacers. not really that bad.
i would go 3". i bought the 2" and am slowly migrating to the 3".
Administrator
I would stay with a good 2", be it OME which is what I run or RTE, the other good choice.
If you go to Lucky8 they have a few packages from OME, medium or HD. If you play a little hard, go with their HD set up and a new OME steering stabilizer. That along with a good set of tires and maybe reactivating your CDL t/case, will make a good all around vehicle on and off the road.
Discussion Starter #4
That kit from rovertym.. is it complete? Thats my main concern.. I want to buy one kit lift it once and not think about it any more.. Its hard to put a handle on exactly what is needed.. Some folks talk about drive line mods that are needed.. i saw one sight that had rear sway bar extensions.. another that had an adjustable.. front sway arm or somthing like that.. Can i buy one 3 inch lift.. with all the parts to correct the problems it might cause..?? . I want to spend most of my weekends on my kayak fishing not working on my car...
I just went on the rovertym site and the kit look pretty good.. It had all these parts that i dont see on a lot of other kits.. but at the bottom of the page it said..*Note: 3" and 5" kits do not include driveshafts .. will i need that too? is their anything else i might need if i get this kit...
new drive shafts are not NEEDED for a DII. with that said, it is higly advisable that you get the front driveshaft rebuilt with greasable u joints. the factory units are sealed. then grease every 3K miles and you're good to go. some people say replace the rear rotoflex driveshaft with a ujoint shaft. personally, i like the rotoflex because it is easier than a ujoint to change out and i have a couple spare rotoflexes that only cost me $10 for the lot.
the DII handles 3" lifts very well without NEEDING new radius or trailing arms. the 3" kit is very bling with the shocks everything you get, but you'll never have to redo it ever again.(not to mention the bilstein shocks are completely rebuildable. in other words, they'll be the last shocks you ever buy for your disco.0
Discussion Starter #6
Why do you highly advise rebuilding the drive shaft.. does the lift cause a lot of extra stress on these places.. how hard is that to do and what is the cost?
Whats a rotoflex drive shaft.. why do some folks say change to a ujoint shaft.. What issues does the lift cause that this would fix? It must not be somthing real bad since you choose not to.. Why do you have so many.. do they break easily after the lift.. or do they commonly break when you do serious off roading..
man i sound like a two year old..:D why why why:dunno:
all the info has been really helpful..
got mud?
michaels and serious off roading? :lol:
Honestly. If you don't plan on doing that much offroading. Then either an OME lift from Lucky8 Llc. - Take the road less traveled...
or a 2" lift from Rovertym will be plenty.
Some people just like sounding cool talking big lifts and such. The smaller the lift the less problems you will have.
Also what size tires do you plan on running? If you plan on running anything less than 33" than there is no need for the 3". To keep the stock axles/drivetrain happy just stick with some 32s.
Have fun fishing. ;)
and you would know how? you have never "wheeled" on anything more than flat ground. i don't do "serious" off roading or rockcrawling, but i do what i feel comfortable with. i have a better spare parts collection now, so i'm not worried about breaking axles anymore.
that's probably the first half-way intelligent thing i've ever seen you say. and 33s fit on a the rovertym 2" lift fine.
Discussion Starter #9 (Edited)
I plan on running the largest tire my lift will allow me to...
Lets just assume i want a three inch lift.. What parts do I NEED to have in your opinion to have a trouble free problem free lift..
Coils
New Shocks
??? what elses( longer brake line, extended rear sway bar links,adjustable Panhard Rod)
What size lift do you have and what parts did you install to get that lift?
I like the look
I think these points say it all.
That is, has only just got it and does not really know what it will do standard, so has no real requirement for mods.
Does not plan to do any serious off-roading, so really doesn't need any mods.
Wants to do it only because he reckons it looks good.
Not sure how a spring lift improves the performance of a Disco.
I would listen to Michaels as he knows a lot about people with your requirements.
Discussion Starter #11
I have had the vehicle for 5 years now silly.. I bought it for my girlfriend she just didn’t want me lifting it or changing the wheels or touching it at all for that matter... So I am pretty familiar with the vehicle and what it’s capable of... I have personally lifted and owned a Nissan an s-10 blazer a jeep Cherokee and a Toyota four runner which was my previous fishing truck... So i am not new to off roading or lifting trucks..
So please spare the elites bs for someone else... I am just here trying to get information from people that have experience with these vehicles not to have you talk down to me so that you can feed your ego....
I want a three inch lift... If it turns out that its to big of a pain in the ass then I will settle for 2inch... Simply because I am not making this vehicle to be a trail rig... I am making it to carry my kayaks and all my fishing gear. If someone on here has a three inch lift I would appreciate knowing what issues it caused and what needed to be done to correct those issues... Then I could make a decision on what I want to do...
Thanks to everyone on here for the useful information that you have provided... I really appreciate it...with the exception of this guy I am really getting some good info..
:wave:
:wave:
like i said, rovertym has EVERYTHING you need. driveshafts won't be necessary. rovertym will sell everything required to make this work. my setup drives so much nicer than it did stock with the rovertym suspension.
Discussion Starter #13
Thanks for the info.. So that rovertym 3 inch lift is totally complete i wont have to buy anything else.. Awsome..
Do you run the 3 inch rovertym ?
got mud?
Yes the kit does come with everything. I can see you are used to jeeps, toyotas, and other trucks that usually advertise 3", 4.5", and 6" ect lifts.... This a rover, a totally different rig then the usual gang.
3" to carry kayaks and go fishing is definitely overdoing it. But hey, its just for the looks right? The RTE 3" is a great lift kit to get. Most who get that kit do a fair amount of wheeling.
So basically 1300 for the 3" or 600 for the 2".
i would say it's not "just for looks" the performance is quite noticeable. longer travel shocks keep the wheels on the ground longer, so traversing terrain is easier. plus, the ride with shocks valved correctly is astounding. besides, you don't know what the trail is like to get there. i've seen plenty of great fishing spots at the end of tough trails, whether while out hiking, driving, or in pictures.. it just depends on where he wants to go fishing.
i do not have the 3" lift, but i have components from it. i have 2" lift in the front and 3" in the rear (gives it a slight raked look, which i like). i have remote resivoir fox shocks in the rear and extended brakelines. basically, i have half the 3" kit. i've just chosen to do it gradually over time.
Discussion Starter #16
NO it’s not just for the looks... and yes I am beginning to see that a big difference does exist... MY last lifts were 4.5, 4, 6 inch lifts... The rover community seems to react as though I building a rock crawler to drive down to the local pond and fish...LOL It's just a 3 inch lift I didn’t take it to be that big of a deal..
But yeah I am a pretty serious fisherman and go a lot of places and would rather be over prepared then under prepared... My 4runner was my last rolling tackle box and many of its duties include taking my family camping riding a few trails... Driving on many a beach... So no worries my Land rovers will be well tested when I am done with it... Its main purpose will be my fishing truck but it will end up my play vehicle...Oh yeah it has to be able to launch my jet ski off a few sandy beaches... Oh and don’t forget the snow!! Some of my winter hunting spots get snowy...
Is that your vehicle in your avatar? That looks pretty much like what I had in mind for mine... What lift and tires do you have... What other mods have u done...
Thanks again for the useful info...
1300 sounds good to me... I think I may just go with that...
Discussion Starter #17
I did that with my cherokee.. Started with 2 then wanted more so then went to fourand a half...
:lol::lol::lol: You are taking over from Hank in the humor department. Stick to your cruising.
When someone states that want a lift without any real reason, it is just for looks. If you are going to be carrying Kayaks on the roof, why would you want it higher off road, or don't you have trees over there.
got mud?
Exactly!
Why get more than you need.. He just wants to make it to the fishing spot and make it back home. He doesn't need to go all out on RTE's 3" lift kit.
He is going to have a tough time strapping those kayaks down with the 3" lift and 33's. I say 33s because he said he is going to fit the largest tire his lift allows.
By the way, with the kayaks, RTE 3", and big tires. Kiss your mileage goodbye. Lets hope that fishing spot isn't too far away from home. ;)
Reptile Expert
Exactly!
why i'm only going with an RTE 2" kit in the next month or so. 3" would be overkill for me and my uses.
1 - 20 of 333 Posts
