1 - 1 of 1 Posts
I hate to do this but up for sale is my 2000 Disco. I purchased it three years ago with cracked block. I then purchased a short block from Paul Grant and built up the top end. Every part on the engine is new with less than 3k on it. ie arp studs, timing chain, oil pump, oil pump gear, water pump, color thermostat, etc. It has new slotted and drilled rotors I also have steel braided brake lines not installed. The trunk requires a few things left to be perfect. I the front driveshaft needs to be replaced. Its out ready to be rebuilt. It needs and idler puller. The power steering pump leaks and transmission pan leaks. The interior is nice, I've painted the headliner. This is a good truck I just dont have time for it any more. 2800 obo...
The Images i have are to large to upload. If you are interested txt me and i will send pics
Duane
404-731-5502
1 - 1 of 1 Posts
