1 - 4 of 4 Posts
I have replaced the crankshaft sensor, throttle sensor, and put a new battery in it. With all that it wont strt now. Im.trying to rule out everything before shelling out money for a new fuel pump. So is there anything else it could be?
Go under the rear end of the truck and smell for fuel. Its not uncommon for them to crack and cause a hard start (It happened to me). Also check the relay for the fuel pump (swap it with the window washer pump) and all fuses, a fuse could make your truck not start sometimes (also happened to me, camshaft position sensor).
1 - 4 of 4 Posts
