1 - 2 of 2 Posts
Changed battery in my 2000 P38 and now alarm is on all the time and only drivers door locks and unlocks with the key. Can not resync fob so fob does not work to lock or unlock vehicle. All other doors can not be opened even from the inside. Even if i unlock the drivers door with the key when i open the door the alarm sounds. I can arm and disarm the alarm with the key(well i get the one and two beeps from the horn) if i try to start the vehicle the alarm goes off. I beleive i am stuck in superlock mode. How can i disarm this???
Have you changed it with an OEM battery?
Usually and virtually all the locked electric functions could be solved with the diagnostic tool. So should find an workshop near you who uses the diagnostic tool specially for Land Rover and connect to your car and there are several options to erase the electric errors.
1 - 2 of 2 Posts
