1 - 5 of 5 Posts
Discussion Starter #1
Wanted to purchase the drive belt, at the auto parts store they had two type of belt, I'm not sure what belt I need, can somebody shed some light, not to mechanically inclined. Thanks.
Super Moderator
Welcome to the forum
There’s 2 different belt lengths
With and without active cornering enhancement.
Easiest thing to look for 👀 if you don’t know would be whether there are 1 or 2 fill caps on the powers steering resivoir ( right by the air filter housing.
If there are 2 and a pump (usually with a black plastic cover) up high and outboard of the a/c compressor-then you need the longer belt.
Hope that helps
Red explained how to determine if you have ACE or not. Once you figure that out, if you have ACE, then you need P/N ERR6896 and if you do not have ACE, then you need P/N ERR6898
1 - 5 of 5 Posts
