Trying to chase down my vibration problem. Bought this truck about 3 months ago and it's almost undriveable on the highway, and pretty annoying in the city
Symptoms:
I don't have any engine codes, I do have the 3 Amigos but doubt that it's related.
Is it possible I have some kind of misfire on acceleration?
Things I can try:
I have an independent Land Rover shop around the corner from me so I can also get them to take it for a spin to give me their opinion, just want to make sure I've tried the obvious/easy stuff first.
Thanks!
2002 Land Rover Discovery II SE, 4.0L, 140k miles
Symptoms:
- Vibrates when first accelerating (~700-1000rpm) then gets better and comes back on strong around 1900-2000 rpm
- This happens both while driving and also if I'm just sitting in Park or Neutral and revving the engine up
- Doesn't seem to matter what gear I'm in
- Not very much vibration at idle
- Replaced front drive shaft u-joints with greasable ones, replaced rear rotoflex joint, had both shafts balanced by a driveline shop
- Replaced both motor mounts and both transmission mounts
- Coolant flushed, oil changed, power steering pump and steering dampener replaced
- New spark plugs and leads
Things I can try:
- compression check
- pull spark plug leads one by one to see if there is an effect
- remove the serpentine belt to see if it's an accessory issue
- some threads say to check the injector harness in case there are issues there
- injector balance? does anyone know how to do this? do i need a special computer for it?
Thanks!
