1 - 13 of 13 Posts
2002 Discovery with over 150K Miles The u joints and the shaft have the zerk fitting. Does this means they were replaced already ? I was reading about this issue and was going to change them, but if they were change once before and there's no problems...Should I change them anyway ?
Many thanks for all you help in the past and
Thank you again.
It should mean that. Keep them greased and inspect them fairly often. I don't know if I'd replace them unless you think they're wearing out. Otherwise save the money for the next that breaks. Don't forget there's a plug on the shaft itself that you need to take out, screw zerk in, grease the shaft, and replace the plug....unless someone has installed a fitting in the spot when they rebuilt the shaft. I think you have to use a different fitting (forget what they're called) to leave it in.
Thank You !
Does anybody know what type of fitting we need to grease the shaft ?
Much oblige...
certified idiot
those joints look pretty dry - I would grease them as soon as you can. I do mine every 3 to 5K miles.
to leave the fitting in the shaft you need a flat zerk (although I have left a normal zerk in for thousands of miles with no problems - it should be a flat zerk though just in case you snap it off)
and you grease it with a needle fitting
I also find the u joints with the zerk in the end cap much easier to grease than those with the zerk in the middle of the spider.
cheers
Barri
Discussion Starter · #5 ·
Thank You !
cheers
Barri
Cheers Barri and thank you ..very helpful.
Administrator
Anyone have a spicer part number on these joints?
certified idiot
should be spicer 5-153x for the standard U joint and spicer 5-433 Lx for the one with the nipple in the end cap. Those numbers are from an old list so check before you order.
Discussion Starter · #8 ·
Can not findthis U-Joint : Spicer 5-433 Lx
Thank you !
I have done my searches ...I went to Dana no luck went to Ebay no luck ...I have 2 years old twins and Im it...Don't have much time today...need your help please...
:help
Does anybody know where to find this U-Joints
SPICER 5-433 Lx
Many Thanks , You are all very kind !
certified idiot
looks like odbrain has it :D
my numbers were handwritten - could well be 1x not Lx
if thats right then as he says it has been replaced by 5-1310-1x
Discussion Starter · #11 ·
Thank you for the rescue , You all !
Guru .
You are very humble.
Thank you.
I'm placing another Thread, regarding piston rings and Rod Bearings..I'm about done with the top overhaul, but I've been told to pay attention to the block too...the piston rings and the rod bearings for starters ...
Where is your heart regarding what we could do to the block?
indebted as always
The Twins
Discussion Starter · #12 ·
Thank You
Perhaps 1x instead of Lx. Maybe 5-1310-1X is the new version.
I spent at least 4 hours searching from 11 pm to 2 AM and at 8:45 AM call and spoke to a few regional managers from Dana...they were both driving so they couldn't help me at the time....They were great !
I sincerely appreciate your help...
Thank you
Discussion Starter · #13 ·
Very Helpful
Thank you !
1 - 13 of 13 Posts
