1 - 5 of 5 Posts
Discussion Starter #1
I have a 2002 FL SE which is in Mint condition.
There are 4 things I would love to have answers or suggestions on:
1. Only the tweeters work in the whole vehicle. Once in a blue moon is there a crackle that comes out of the passenger door speaker but other than that, since owning the vehicle this past August 2010, I do not know what the sound is like from the Harmon Kardon system. The rear subwoofer works but other than that, nothing else.
2. When I turn corners sharply, I get a grinding or crunching sound from the rear. Any ideas what I need to look at when taking it to the dealership?
3. Is the gas cap on the LR SE something that causes the engine light to come on? Sometimes when I fill the vehicle with gas, the light goes off. If the gauge comes closer to empty, it comes on.
4. The sunroof is making a horrible sound when trying to close. Possible motor problems? I use my hand to help move it along to close but opening works just fine.
Cheers.
John
Halifax, Nova Scotia
Canada
Cheers.
John
Canada
There is a viscous coupling between the two pieces of the driveshaft, it's supported front and rear by a bearing. The rubber around the bearing tears and can cause similar problems to what you've described.
If this is it, I have one of the carrier bearings in stock.
Hello,
PTS is dead on! I have replaced my rear (first) and later the front. Same symptoms...now gone. Parts and labor for each were around $350 or so---not at the dealer!
Julian
Thanx Knac.
Pool boy, buy this part from me! I doubt I'll ever need another one again(it's a long story how I got an odd number of them).
If you decide you need both of them, I can get another one for you.
...Cheers.
John
Canada
John, you need to check amplifier and its connections - it is unlikely that all the speakers lost contact but main audio harness can be lose. You also may want to look into installing aftermarket receiver/amp...
1 - 5 of 5 Posts
