Down to the crankshaft now after openning up the engine. My problem is my rod journals measure 2.185 in.(took to machine shop) Converted on google this is 55.499 mm. Reverse 55.500mm (standard journal measurement in Land Rover Manual) and I get 2.18504 in. Looks like I have a standard size journal in mm right? Here is the problem... The Land Rover manual also gives the rod journal in inches. 2.20 inches.. I called tech at Atlantic British and got the same measurent in inches for journals. (converts to 55.88 mm on google not 55.500 as given in manual) I need to have the crankshaft turned and polished to remove wear scratches. By this info I don't know what size bearings to order so I can have crankshaft turned to fit with bearings. What am I missing? This doesn"t add up for me. If I go with the inch measurement given in manual and by Atlantic British then I'll have to order bearings 2 sizes over and only have 5 thousands to turn and polish. If I go by my conversion on google of 2.185 in = 55.499 mm then I can buy the 1st oversized bearings.
