1 - 13 of 13 Posts
Discussion Starter #1
I figured it was just a misfire, bad plugs or bad wire, and before I could get it to the mechanic, my son was driving it and it basically shut down in the middle of driving the car down the road, and now won't start. Any ideas?, bad fuel pump, bad wires, thoughts????????????
very disco
Can you better describe your no-start behavior?
The more details the merrier
Discussion Starter #3
Well, it just cut off, and then wouldn't turn over, not dead, it just wouldn't catch, so had to tow it home, then today later after it maybe cooled down, it started again, weird.
Confused. If it just would not catch, doesn't that mean that in fact it was turning over?
Super Moderator
Pretty much a textbook crank sensor failure (starts cold but not hot)
As for the codes likely not related and a crank sensor commonly doesn’t set a code.
Do some reading and search crank sensor failures
Hope that helps point you in the right direction
Super Moderator
Is this something that you are willing to do yourself?
very disco
it wouldn’t be very expensive at all to DIY, just time consuming for the novice or ill-equipped.
The part is cheap get a Bosch unit the other have been know to be problematical
Give yourself an afternoon, undoing the 2 bolts is easy getting the connector apart is not. It literally takes about 15 minutes to remove and install the unit and it took me 1.5 hours to get the cable disconnected and reconnected. The connector is at the top rear of the left side of the engine Kind of behind the exhaust and below the heads as inconvenient a spot as could be found
Search for Land Rover Discovery II CPS replacement to get an idea
1 - 13 of 13 Posts
