1 - 2 of 2 Posts
Hi Guys - Great forum and great resource. I have read many topics here and n used the advice and RAVE manual but am perplexed with my radio. I hope one of the members can help. I have the Alpine system with CD changer and amp under the front seats. Radio powers up but no sound. Fuse on radio back side is good. Fusible link 7 is also good under the hood. Fuse 17 in the car is also good. What is interesting is there is power to the amp at pin 5 of nearly 6 volts when I power on the car and check the harness. However when I connect the harness to the and and check pin 5 voltage it drops to 1.5 volts or so..... I have plugged in other amps with same result. I swapped radios and nothing changes. I also changed the steering wheel control and all functions from the steering control but the volume. Am I missing something here??? Aaaargh!! Pls help. - Chris:help
1 - 2 of 2 Posts
