So a few months ago my 2003 Disco HSE was having a hard time starting. The started sounded like the battery was low but when the key was turned of and back on it would fire up just fine. Then it quit starting all together. I changed the battery and the starter and still nothing when the key is turned to crank the truck. The starter has power from the main line, but the small lead wire does not have power when the key is turned. I've checked all the fuses and tried moving the relays around to see if they might be the issue to no avail.
Anyone have any ideas on what the problem might be?
PS I tried the lock and unlock with the key pad and everything in the vehicle other than the started seems to be working. The battery has proper voltage.
Thanks
:beer:
Thanks
:beer:
