No longer for sale
2004 Discovery SE7 black with black interior
HID low beams
3" Rovertym HD springs*
D1 rear spring seats
Extended Terrafirma shocks
OME steering stabilizer*
Extended Goodrich SS brake lines
Extended sway bar links
Hard Labor Creek Fabrication front bumper with A-bar and skid plate. *2x Hella rallye 4000 cornering lights. 2 mounts that have recovery shackles
Hard Labor Creek Fabrication rock sliders
Hard Labor Creek Fabrication Rear bumper with integrated tire carrier, removable jerry can holder, and High lift jack mount. Bumper still has 2"*receiver*using factory mounts.
Hard Labor Creek Fabrication Gas tank skid plate
Everything mounted with grade 8 bolts and locking nuts*
Warn Powerplant Dual Force HP winch*
All fluids brand new- Diffs, tfer case, coolant, brake, power steering,
Brass plug on radiator hose T
New thermostat*
Ashcroft 4.37 gearing
Ashcroft Heavy Duty Half Shafts and CV Kit
Ashcroft Heavy Duty Rear Half Shafts
ARB RD128 front/rear lockers with ARB high output compressor under front passenger seat
Safety Device high rack with frametek flooring. 4 Hella 700ff lights and Hella dual floodlight in rear.
315/75-16 Goodyear Duratrac tires. Spare new, others maybe 3k miles
Pro comp steel wheels with land rover steel lug nuts - Also comes with 4 Land Rover 16" Alloys and caps
JVC KD-NX5000 navigation head unit with 30pin ipod input. Kicker 6.5 comps in front door.
Tom woods double cardon rear drive shaft.*
Rovertym crossmember spacers
QT front and rear diff guards
Flowmaster muffler with resonator deleted
Front drive shaft ujoints and centering ball replaced with greasable ones
DieHard Marine Battery Platinum PM-1
3 amigos fixed by grounding abs module.*
D1 wiper arms so you can use non land rover blades
HD tierod from [email protected]*
Everything purchased from Lucky8 or Denny @ HLC
Only thing is check engine light from SAI. I've replaced the pump and the solenoid. I think it's the pipes. But I am in Kansas. No emissions testing so I didnt give a crap.
3 Amigos fix completed by grounding
Build thread with some pictures
04 D2 locked on 35's - DiscoWeb Message Boards
Don't need to sell but might. 120k miles. Slow drip of coolant. I'd replace the gaskets soon.
Have brand new Bosch platinum plugs and the blue 8mm wires, original 3rd members, stock 16" wheels.
HID low beams
New thermostat*
