1 - 3 of 3 Posts
I have a new hobby and a whole lot of other things going on. Time to let the 'ole mall crawler go.
2004 D2
Mechanically, nothing at all out of line. When something breaks, I fix it. Cosmetically, there are a few dings but nothing major. I live in Houston and she still gets parked in the front row at the Valet.
I have done some state park trails/off-road parks in Marble Falls, she has probably been on the trails for a cumulative week since I have owned her. Never anything punishing, no mud.
Everything works. Sunroofs are operational and weather tight, I recently changed the headliner and sealed all of the drains. Interior is clean and tight.
I have addressed everything that is likely to give you any problems for a good long time, nothing was skipped over for convenience or expense... I had been planning to keep the truck indefinitely.
120,xxx miles
More pictures to be added soon.
$13,000.00
Not interested in trades or owner financing.
The truck was primarily built by ek5usmc (on Discoweb.org) search for his threads and you can see all of the quality work that went into the original build.
Modifications:
3'' Heavy Duty RTE Springs
1'' Aluminum spacer in rear
Bilstine 7100 Reservoir Shocks
RTE DP2 Watts Linkage
RTE Spring Retainers
Steel Braided Brake Lines
ABS Extensions
SlickRock Quick Disconnects Sway Bars, Front
Longer Sway Bars in the Rear
Tom Woods Rear Drive Shaft
4 Bolt Flange Kit
Rebuilt Front Drive Shaft
RTE Full Brush Guard Wide Face Front Bumper
10,000 lb. XRC Winch with Rubber hook holder
RTE Aluminum Front Skid Plate
RTE Rear Bumper with Nerfs
RTE Rock Sliders with Nerfs
QT Differential Guards
LG Aluminum Gas Tank Skid
HID Conversion Head Lights
New 1/8'' Steel Frame Horns
Rover Racks Ladder
RTE Spare Tire Mount
(not installed but included) RTE Washer Bottle Relocation Kit
7/27/13
Differential Lube Changed Front and Back (75/90 Mobile 1)
Transfer Case Lube Changed
Right Front Wheel Bearing Replaced
Right Front Wheel Position Sensor Replaced
New Bank 1 Coil Pack
5/22/13
New Right Front Tie Rod End
Complete Lube and Maintenance on Front End Suspension
2/15/12
Reverted To Stock Exhaust
Repaired Left Rear Body Cap
New Headliner
Tightened and Adjusted the XYZ Sensor
12/31/2012
New Windshield Wiper Assemblies
12/19/2012
Odometer: 117,269
Coil pack was causing engine misfire. Found electrical short in harness between ECU and coil packs.
New Bank 2 Coil Pack
New Spark Plugs
New Ignition Wires
New Secondary Air Pump
New Left Tail Light (from previous damage)
New Left Bumper Trim
New Left Front Door Latch
Performed Throttle Body Heater Bypass (slight coolant leak at interface)
Removed aftermarket Flowmaster Muffler and replaced OEM exhaust.
12/18/2012
New Headliner
Rebuild left bolster and cracked vinyl on Driver Seat
6/14/2012
New Viscous Fan Clutch
New Accessory Drive Belt
7/28/2011
New MAF sensor
6/21/11
New Power Steering Pump
New Front Passenger Window Motor
New Fuel Pump
Cruise Control Issue Resolved
Mobil 1 Synthetic T-Case
Pennzoil High Mileage 10/40
4/27/11 @105,000 Miles
Replaces all 5 tires with BFGoodrich Mud-Terrain T/A KM2
4/26/11
Replaced Rear Rotors and Pads with NAPA Premium Rotors and Ferodo Pads
4/25/11
Replaced Front Rotors and Pads with NAPA Premium Rotors and Ferodo Pads
4/24/11
Replaced Front Upper and Lower Ball Joints
New Horn Buttons
New Steering Wheel Radio Controls
12/20/10
Full Pennzoil Platinum Oil Change
11/13/10
Replaced Engine Water Pump
Replaced Water Pump Gasket
10/12/10
Front and rear differential fluid change 75/90 Mobile 1
7/25/2010 (96,240 mile Engine Overhaul)
Replaced Head Gaskets
Replaced Exhaust Manifold Gaskets
Full Valve Job on Heads
Dipped and decked 3/1000th
Replaced Front Cover gasket
Replaced Front Crank Seal
Replaced Timing Chain and Gear Set
Replaced Valley Gasket
Replaced Intake Gasket
Replaced Rocker Cover Gasket
Re-wrapped degraded wire harness cover
New Air Filter
New Thermostat
New Bosh Platinum+4 spark plugs
Pennzoil 5W/30 and Oil Filter
New Fuel Line and Evap. Line
Replaced Throttle Body Heater Plate Gasket and Hardware
______________
Maintenance just prior to Purchase at ~80,000
Magnecor 8mm plug wires
New Fram Air Filter
Engine flush
Mobil 1 Full Synthetic and Molbil 1 oil filter,
Coolant flush
Transmission flush
Mobil 1 Full Synthetic +Filter Kit,
Power Steering flush
Red Line Full Synthetic Power steering fluid,
Brake flush
Prestone Full Synthetic DOT 4,
Transfer Case and Differentials changed with Lucas Full Synthetic 75w90 ,
Fuel Injection + Intake Treated with Sea Foam + cleaned the Throttle Body.
New Serpentine belt
MAF sensor
4 New Rotors and Pads
2 New Motor Mounts
New Transmission Mount
New Transfer Case Mount
Sill Wiper Blades
· DiscoVT
this still available?
· disco biscuit
Wasn't this truck stolen at one point? How'd you find it? Seems like an important piece of Info for a potential buyer. Hell I had that thread bookmarked cause you live close to me but never heard an update. That thread is now missing, I think.
1 - 3 of 3 Posts
