1 - 4 of 4 Posts
So I have a 2004 D2 with 111K miles.
All my interior and exterior lights are working EXCEPT the front right turn signal. The right rear turn signal and right side marker lights flash but the front doesnt. On the dash the green arrow blinks fast like the bulb is out.
I checked the turn signal bulb and verified that the bulb is good. The connections on the bulb socket are clean and look new. I checked the fuses; all good. I checked the ground behind the drivers side kick panel; looks factory new. All the hazards work, with the exception of the front right turn signal. I checked the relay (R2) in the fuse box under the steering wheel but cant tell if it is bad. If the relay were bad the rear and side marker lights wouldnt flash, correct? So is there a different ground for just the right turn signal that I havent found yet?
Any advice?
'03 Disco SE
Are you positive the bulb is good? Did you swap the two sides to check? A lot of times the bulb will "look" good but will have some minor damage that is preventing it from working.
Replace it just to be sure and come back if it's still not working.
It may be a wire on the inside of the headlight assembly. Since it's only one plug going in, there are wire inside that might come loose. Use a test light on the plug that going into the assembly to see if the flashers are working there. That should tell you if the headlight assembly has a bad wire, or the plug to the light.
Mike Russell
Age 18
2003 discovery se
Lover of Rovers
1 - 4 of 4 Posts
