Helpful Diagnosis if possible.
Had very apt/mechanical neighbor replace my Valve Cover Gaskets and Upper Manifold Gasket over the weekend. When we got it back and started it up - there was a rough Idle I noticed while in Park - this rough Idle also shows up in reverse - it does not show up in Drive or while stopped at a light with foot on brakes. After a little drive for a test run - the engine service light came on. I got the following codes. I also noticed what looks like coolant leak on the driver side Valve cover Near some hoses - it may be coming from the hose actually attached to the Valve Cover or 2 other hoses right above - see images. Any assistance from this group is appreciated - my neighbor is of course going to go back under the hood but I would like a little bit of direction from the dedicated specialists on this site.
P0130 - Powertrain - 02 Sensor Circuit(Bank 1 Sensor 1)
P0171 - System too Lean(Bank 1)
P1300 - Powertrain - Tap for Multiple Descriptions
P0305 - PowerTrain - Cylinder 5 Misfire Detected
P0307 - PowerTrain - Cylinder 7 Misfire Detected
P0300 - PowerTrain - Random/Multiple Cylinder Misfire Detected
