I have a 2005 LR3 HSE with 107,000 kms.
Recently a Suspension Fault triggered. I took vehicle to dealer and they informed me that the compressor needed replacing. They replaced compressor but fault continued. Fault only triggers when on highway after driving about 85 kms or approx. 45 minutes.
If you stop, turn off, and then restart, fault disappears.
I found a video from RSWSolutions on how to test:
Last night I raised vehicle to off road height. I measured each wheel height from ground to underside of wheel well trim. I then removed fuse F3 as suggested in video.
Measurements are:
LF: 87.2 cm - lowered to 81cm - loss of 6.2cm
RF: 87.2 cm - lowered to 82 cm - loss of 5.2cm
LR: 90.5 cm - lowered to 87.3 cm - loss of 3.2 cm
RR: 89.0 cm - lowered to 86.3 cm - loss of 2.7 cm
Any thoughts on what might be causing fault?
Measurements are:
