1 - 5 of 5 Posts
Discussion Starter #1
Hi,
Just installed Proud Rhino lift rods front and rear. Rear end is totally jacked up in the rear, but the fronts are on the bump stops. I get the messages Extended Mode, also more often Reset height if clear of obstacle.I am baffled. It's an easy job, but I'm lost.
very disco
It sounds like you need to calibrate your EAS without the rods, then reinstall.
very disco
You could try removing the lift rods, disconnecting the battery for some time, jacking up the front of the truck to a normal height, and reconnecting power/starting the truck.
I disconnected the battery from both terminals about half an hour ago, and am going to let it sit overnight. We shall see. Thanks for the input! I appreciate it!
1 - 5 of 5 Posts
