1 - 5 of 5 Posts
I need to change out my radiator, but can not get my fan loose. I have all the screws, bolts and clamps loose, but can not budge the fan. I have read that I need to loosen the fan bolt by hitting the wrench to the left, but it wont move.
Am I hitting the spanner in the right direction and can anyone give some advice. Thank you
You need two wrenches to remove the fan. I believe the fan wrench is a 36mm size and then you need something else to hold the spindle. I think it can be done with just the 36mm wrench and a pry bar to hold the spindle, but I don't think I'd do it that way if I had a choice. Also, keep in mind that the fan is reverse threaded, so turn it clockwise to loosen.
member
What's wrong with the rad?
Dave
1 - 5 of 5 Posts
