1 - 4 of 4 Posts
Discussion Starter #1
Hey so after an accident the front suspension dropped and wont come up. The 2 wheels on driver side were torn off in the accident. The rear bags are fine but the front is dropped. I can't figure out if i need to order 2 new front bags or not.
very disco
does the truck try to lift and then error? or does it error the second you start the car?
pulling codes would be helpful, but i would do the soapy water test on both the front bag and the front valve block.
very disco
what codes are you getting?
it could be leaking front bags or a bad front valve block. the front valve block is behind the front bumper on the right hand side, but behind the fender liner on the left front wheel is a harness that carries the EAS circuit. if that harness was damaged it would disable EAS.
1 - 4 of 4 Posts
