1 - 3 of 3 Posts
Discussion Starter #1
2009 LR2, key fob will go in, but have to wriggle it out and vehicle says ignition key still in. Can put my finger inside slot and poke around until it resets. Already had battery changed and reprogrammed, so that is not the problem.
Had a problem removing the key from my "99 DII. Found out that if I turn it over, it will work fine and come out fine; guess one side has worn down some. So I marked the key and always make sure that side is up when I put it in the ignition.
Maybe you can turn the key over and have success? Just a guess.
very disco
My 2006 lr3 key works perfectly on one side and hardly ever on the other
1 - 3 of 3 Posts
