1 - 1 of 1 Posts
Just bought a used 2010 RR Sport with about 110k miles. iid tool ran the faults and showed about 500 faults. Vehicle seems to run fine. Suspension seems fine, windows seem fine, audio seems fine, transmission seems fine. Passed state emissions inspection. No clue where to start other than to start checking grounding points.
Tried the hard reset. Cleared faults repeatedly over the past few weeks and they all come back.
Any suggestions?
The faults are as follows (forgive me for posting all these)
L320 - Range Rover Sport 2010
Vehicle scanned on 11-05-2022 11:16
Using IIDTool BT V4.0 B2803
AAM-Audio Amplifier
  • B1A01-13 (10) Speaker 1 circuit - General electrical failure - circuit open
    ( on 14-02-2025 09:03:46 at 0 km )
  • B1A02-13 (10) Speaker 2 circuit - General electrical failure - circuit open
  • B1A09-13 (10) Speaker 9 circuit - General electrical failure - circuit open
  • B1A10-13 (10) Speaker 10 circuit - General electrical failure - circuit open
  • B1A03-13 (10) Speaker 3 circuit - General electrical failure - circuit open
  • B1A04-13 (10) Speaker 4 circuit - General electrical failure - circuit open
  • B1A07-13 (10) Speaker 7 circuit - General electrical failure - circuit open
  • B1A08-13 (10) Speaker 8 circuit - General electrical failure - circuit open
  • B1A11-13 (10) Speaker 11 circuit - General electrical failure - circuit open
  • B1A12-13 (10) Speaker 12 circuit - General electrical failure - circuit open
  • B1A05-13 (10) Speaker 5 circuit - General electrical failure - circuit open
  • B1A06-13 (10) Speaker 6 circuit - General electrical failure - circuit open
ABS-Brake Module
  • C0030-38 (50) Front left tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
  • C0031-25 (50) Front left wheel speed sensor - General signal failure - signal shape/waveform failure
  • C0031-2F (50) Front left wheel speed sensor - General signal failure - signal is erratic
  • C0031-31 (50) Front left wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
  • C0031-62 (50) Front left wheel speed sensor - Algorithm based failure - signal compare failure
  • C0031-64 (50) Front left wheel speed sensor - Algorithm based failure - signal plausibility failure
  • C0033-38 (50) Front right tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
  • C0034-25 (50) Front right wheel speed sensor - General signal failure - signal shape/waveform failure
  • C0034-2F (50) Front right wheel speed sensor - General signal failure - signal is erratic
  • C0034-31 (50) Front right wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
  • C0034-62 (50) Front right wheel speed sensor - Algorithm based failure - signal compare failure
  • C0034-64 (50) Front right wheel speed sensor - Algorithm based failure - signal plausibility failure
  • C0036-38 (50) Rear left tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
  • C0037-25 (50) Rear left wheel speed sensor - General signal failure - signal shape/waveform failure
  • C0037-2F (50) Rear left wheel speed sensor - General signal failure - signal is erratic
  • C0037-31 (50) Rear left wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
  • C0037-62 (50) Rear left wheel speed sensor - Algorithm based failure - signal compare failure
  • C0037-64 (50) Rear left wheel speed sensor - Algorithm based failure - signal plausibility failure
  • C0039-38 (50) Rear right tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
  • C003A-25 (50) Rear right wheel speed sensor - General signal failure - signal shape/waveform failure
  • C003A-2F (50) Rear right wheel speed sensor - General signal failure - signal is erratic
  • C003A-31 (50) Rear right wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
  • C003A-62 (50) Rear right wheel speed sensor - Algorithm based failure - signal compare failure
  • C003A-64 (50) Rear right wheel speed sensor - Algorithm based failure - signal plausibility failure
  • C0051-28 (50) Steering wheel position sensor - General signal failure - signal bias level is out of range/zero adjustment failure
  • C0062-54 (50) Longitudinal acceleration sensor - System programming failure - missing calibration
  • C0062-64 (50) Longitudinal acceleration sensor - Algorithm based failure - signal plausibility failure
  • C0063-14 (50) Yaw rate sensor - General electrical failure - circuit short to ground or open
  • C0063-1C (50) Yaw rate sensor - General electrical failure - circuit voltage out of range
  • C0063-28 (50) Yaw rate sensor - General signal failure - signal bias level is out of range/zero adjustment failure
  • C0063-41 (50) Yaw rate sensor - System internal failure - general checksum failure
  • C0063-49 (50) Yaw rate sensor - System internal failure - internal electronic failure
  • C0063-4A (50) Yaw rate sensor - System internal failure - incorrect component installed
  • C0063-64 (50) Yaw rate sensor - Algorithm based failure - signal plausibility failure
  • C0063-86 (50) Yaw rate sensor - Bus signal/message failure - signal is invalid
  • C0063-95 (50) Yaw rate sensor - Component failure - incorrect assembly
  • C0063-96 (50) Yaw rate sensor - Component failure - internal failure
  • C0064-64 (50) Roll rate sensor - Algorithm based failure - signal plausibility failure
  • C006A-54 (50) Multi-axis acceleration sensor - System programming failure - missing calibration
  • C101F-49 (50) Generic valve failure - System internal failure - internal electronic failure
  • C1109-24 (50) Vehicle dynamics control switch - General signal failure - signal stays high
  • C1A77-16 (50) Valve relay supply circuit - General electrical failure - circuit voltage below threshold
  • C1A95-64 (50) Wheel speed sensor circuit - Algorithm based failure - signal plausibility failure
  • C1A96-64 (50) Brake lamp switch circuit - Algorithm based failure - signal plausibility failure
  • C1A98-96 (50) Yaw rate sensor circuit - Component failure - internal failure
  • C1B00-29 (50) Steering angle sensor - General signal failure - signal is invalid
  • C1B00-64 (50) Steering angle sensor - Algorithm based failure - signal plausibility failure
  • C1B00-92 (50) Steering angle sensor - Component failure - performance or incorrect operation
  • C1B02-16 (50) Return pump circuit - General electrical failure - circuit voltage below threshold
  • C1B02-49 (50) Return pump circuit - System internal failure - internal electronic failure
  • C1B22-24 (50) Hill descent switch - General signal failure - signal stays high
  • C2009-64 (50) Front axle wheel speed sensors swapped - Algorithm based failure - signal plausibility failure
  • C200A-64 (50) Rear axle wheel speed sensors swapped - Algorithm based failure - signal plausibility failure
  • U0001-88 (50) High speed CAN communication bus - Bus signal/message failure - bus is off
  • U0074-88 (50) Control module communication bus B off - Bus signal/message failure - bus is off
  • U0104-00 (50) Lost communication with speed control module
  • U0123-00 (50) Lost communication with yaw rate sensor module
  • U0133-00 (50) Lost communication with dynamic response module
  • U0140-00 (50) Lost communication with body control module
  • U0300-00 (50) Internal control module software incompatibility
APIM-Acc. Interface
  • U3000-44 (50) Control module - System internal failure - data memory failure
  • U3000-45 (50) Control module - System internal failure - program memory failure
  • U3000-55 (50) Control module - System programming failure - is not configured
  • U3003-62 (50) Battery voltage - Algorithm based failure - signal compare failure
  • U3000-13 (50) Control module - General electrical failure - circuit open
ATCM-Terrain Response
  • C1A02-94 (50) Rotary encoder stuck in the intermediate position - Component failure - unexpected operation
  • C1A01-96 (50) LED circuit - Component failure - internal failure
  • C1A00-46 (50) Control module - System internal failure - calibration/parameter memory failure
BCM-Body Control
  • C1A56-93 (50) Front left tire pressure sensor and transmitter assembly - Component failure - no operation
  • C1A58-93 (50) Front right tire pressure sensor and transmitter assembly - Component failure - no operation
  • C1A60-93 (50) Rear left tire pressure sensor and transmitter assembly - Component failure - no operation
  • C1A62-93 (50) Rear right tire pressure sensor and transmitter assembly - Component failure - no operation
  • C1D21-05 (50) Wheel module - General failure information - system programming failure
  • C1A56-16 (50) Front left tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
  • C1A58-16 (50) Front right tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
  • C1A62-16 (50) Rear right tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
  • C1A56-86 (50) Front left tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
  • C1A58-86 (50) Front right tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
  • C1A62-86 (50) Rear right tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
  • U201F-11 (50) External receiver - General electrical failure - circuit short to ground
  • U201F-12 (50) External receiver - General electrical failure - circuit short to battery
  • C1D18-00 (50) Localisation failed
  • B1182-51 (50) Tire pressure monitor system - System programming failure - not programmed
  • C1A57-12 (50) Front left initiator - General electrical failure - circuit short to battery
  • C1A57-14 (50) Front left initiator - General electrical failure - circuit short to ground or open
  • C1A59-12 (50) Front right initiator - General electrical failure - circuit short to battery
  • C1A59-14 (50) Front right initiator - General electrical failure - circuit short to ground or open
  • C1A61-12 (50) Rear left initiator - General electrical failure - circuit short to battery
  • C1A61-14 (50) Rear left initiator - General electrical failure - circuit short to ground or open
  • C1A63-12 (50) Rear right initiator - General electrical failure - circuit short to battery
  • C1A63-14 (50) Rear right initiator - General electrical failure - circuit short to ground or open
  • B1D17-87 (50) Bus circuit - Bus signal/message failure - missing a message
  • B112C-87 (50) Interior motion sensor - Bus signal/message failure - missing a message
  • C111A-11 (50) Right stoplamp - General electrical failure - circuit short to ground
  • C111B-11 (50) Left stoplamp - General electrical failure - circuit short to ground
  • B1095-12 (50) Windshield wiper on/off relay - General electrical failure - circuit short to battery
  • B11C2-12 (50) Power striker close relay - General electrical failure - circuit short to battery
  • B11C3-12 (50) Power striker open relay - Short circuit to battery/overload - General electrical failure - circuit short to battery
  • B1249-15 (50) Start button illumination - General electrical failure - circuit short to battery or open
  • B1249-11 (50) Start button illumination - General electrical failure - circuit short to ground
  • B1096-12 (50) Windshield wiper high/low relay - General electrical failure - circuit short to battery
  • B1097-12 (50) Heated windshield relay - General electrical failure - circuit short to battery
  • C2004-12 (50) Headlamp washer relay B - General electrical failure - circuit short to battery
  • B1C90-11 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to ground
  • B1C90-12 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to battery
  • B1C90-13 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit open
  • B10F8-11 (50) Accessory socket 'A' relay - General electrical failure - circuit short to ground
  • B10F8-13 (50) Accessory socket 'A' relay - General electrical failure - circuit open
  • B1102-11 (50) Enable crank relay short to battery (or relay always closed) - General electrical failure - circuit short to ground
  • B136B-15 (50) Suspension control module wake-up signal - General electrical failure - circuit short to battery or open
  • B1115-11 (50) High mounted stoplamp control - General electrical failure - circuit short to ground
  • B111E-11 (50) Luggage compartment lamps - General electrical failure - circuit short to ground
  • B111E-15 (50) Luggage compartment lamps - General electrical failure - circuit short to battery or open
  • B113C-11 (50) Hazard switch illumination - General electrical failure - circuit short to ground
  • B113C-13 (50) Hazard switch illumination - General electrical failure - circuit open
  • B113C-12 (50) Hazard switch illumination - General electrical failure - circuit short to battery
  • B1140-11 (50) Engine crank authorisation - General electrical failure - circuit short to ground
  • B136E-11 (50) Glove box release motor - General electrical failure - circuit short to ground
  • B136E-15 (50) Glove box release motor - General electrical failure - circuit short to battery or open
  • B12E7-23 (50) Glove box switch - General signal failure - signal stays low
  • B1146-11 (50) Passive anti-theft sounder supply - General electrical failure - circuit short to ground
  • B1146-15 (50) Passive anti-theft sounder supply - General electrical failure - circuit short to battery or open
  • B123A-11 (50) Front left turn signal - General electrical failure - circuit short to ground
  • B123B-11 (50) Front right turn signal - General electrical failure - circuit short to ground
  • B1247-11 (50) Rear left turn signal - General electrical failure - circuit short to ground
  • B1248-11 (50) Rear right turn signal - General electrical failure - circuit short to ground
  • B124A-11 (50) Right daytime running lamp - General electrical failure - circuit short to ground
  • B124A-15 (50) Right daytime running lamp - General electrical failure - circuit short to battery or open
DDM-Driver Door
  • B10EB-11 (50) Driver's door double locking motor - General electrical failure - circuit short to ground
  • B10EB-15 (50) Driver's door double locking motor - General electrical failure - circuit short to battery or open
  • B10ED-11 (50) Rear door driver side double locking motor - General electrical failure - circuit short to ground
  • B10ED-15 (50) Rear door driver side double locking motor - General electrical failure - circuit short to battery or open
  • B1108-11 (50) Driver's door central locking motor - General electrical failure - circuit short to ground
  • B1108-15 (50) Driver's door central locking motor - General electrical failure - circuit short to battery or open
  • B110A-11 (50) Rear door driver side central locking motor - General electrical failure - circuit short to ground
  • B110A-15 (50) Rear door driver side central locking motor - General electrical failure - circuit short to battery or open
  • B110C-11 (50) Rear door driver side power child locking motor - General electrical failure - circuit short to ground
  • B110C-15 (50) Rear door driver side power child locking motor - General electrical failure - circuit short to battery or open
  • B1161-15 (50) Rear left anti-pinch sensor - General electrical failure - circuit short to battery or open
  • B1161-23 (50) Rear left anti-pinch sensor - General signal failure - signal stays low
  • B1162-15 (50) Rear right anti-pinch sensor - General electrical failure - circuit short to battery or open
  • B1162-23 (50) Rear right anti-pinch sensor - General signal failure - signal stays low
  • B1163-11 (50) Left mirror heater output - General electrical failure - circuit short to ground
  • B1163-15 (50) Left mirror heater output - General electrical failure - circuit short to battery or open
  • B1164-11 (50) Right mirror heater output - General electrical failure - circuit short to ground
  • B1164-15 (50) Right mirror heater output - General electrical failure - circuit short to battery or open
  • B1165-11 (50) Front left puddle lamp output - General electrical failure - circuit short to ground
  • B1165-15 (50) Front left puddle lamp output - General electrical failure - circuit short to battery or open
  • B1166-11 (50) Front right puddle lamp output - General electrical failure - circuit short to ground
  • B1166-15 (50) Front right puddle lamp output - General electrical failure - circuit short to battery or open
  • B117C-07 (50) Rear door glass window up - General failure information - mechanical failure
  • B117C-72 (50) Rear door glass window up - Mechanical failure - actuator is stuck open
  • B117C-73 (50) Rear door glass window up - Mechanical failure - actuator is stuck closed
  • B117C-92 (50) Rear door glass window up - Component failure - performance or incorrect operation
  • B117D-72 (50) Rear door glass window down - Mechanical failure - actuator is stuck open
  • B117D-73 (50) Rear door glass window down - Mechanical failure - actuator is stuck closed
  • B117E-07 (50) Front power door glass window - Up - General failure information - mechanical failure
  • B117E-72 (50) Front power door glass window - Up - Mechanical failure - actuator is stuck open
  • B117E-73 (50) Front power door glass window - Up - Mechanical failure - actuator is stuck closed
  • B117E-92 (50) Front power door glass window - Up - Component failure - performance or incorrect operation
  • B117F-72 (50) Front power door glass window - Down - Mechanical failure - actuator is stuck open
  • B117F-73 (50) Front power door glass window - Down - Mechanical failure - actuator is stuck closed
  • B1189-29 (50) Front door glass window position sensor - General signal failure - signal is invalid
  • B118A-29 (50) Rear window position sensor - General signal failure - signal is invalid
  • B118C-04 (50) Left blind spot warning indicator - General failure information - system internal failure
  • B118C-11 (50) Left blind spot warning indicator - General electrical failure - circuit short to ground
  • B118C-12 (50) Left blind spot warning indicator - General electrical failure - circuit short to battery
  • B118C-13 (50) Left blind spot warning indicator - General electrical failure - circuit open
  • B118D-04 (50) Right blind spot warning indicator - General failure information - system internal failure
  • B118D-11 (50) Right blind spot warning indicator - General electrical failure - circuit short to ground
  • B118D-12 (50) Right blind spot warning indicator - General electrical failure - circuit short to battery
  • B118D-13 (50) Right blind spot warning indicator - General electrical failure - circuit open
  • B118E-00 (50) Front left door glass window
  • B118F-00 (50) Front right door glass window
  • B1190-00 (50) Rear left door glass window
  • B1191-00 (50) Rear right door glass window
  • B11B8-11 (50) Driver blind spot warning indicator supply - General electrical failure - circuit short to ground
  • B11B8-15 (50) Driver blind spot warning indicator supply - General electrical failure - circuit short to battery or open
  • B11F6-11 (50) Driver folding mirror motor - General electrical failure - circuit short to ground
  • B11F6-15 (50) Driver folding mirror motor - General electrical failure - circuit short to battery or open
  • B1B70-83 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - value of signal protection calculation is incorrect
  • B1B70-86 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - signal is invalid
  • B1B70-87 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - missing a message
  • B1C09-11 (50) Driver's left/right mirror motor circuit - General electrical failure - circuit short to ground
  • B1C09-15 (50) Driver's left/right mirror motor circuit - General electrical failure - circuit short to battery or open
  • B1C10-11 (50) Driver's up/down mirror motor circuit - General electrical failure - circuit short to ground
  • B1C10-15 (50) Driver's up/down mirror motor circuit - General electrical failure - circuit short to battery or open
  • B1C13-11 (50) Driver's up/down mirror motor feedback circuit - General electrical failure - circuit short to ground
DSM-Driver Seat
  • B1060-11 (50) Seat head restraint motor output - General electrical failure - circuit short to ground
  • B1060-15 (50) Seat head restraint motor output - General electrical failure - circuit short to battery or open
  • B1064-31 (50) Seat head restraint motor sensor - Frequency modulation/pulse width modulation failure - no signal
  • B106D-24 (50) Head restraint up switch - General signal failure - signal stays high
  • B106E-24 (50) Head restraint down switch - General signal failure - signal stays high
  • B1B87-31 (50) Seat height motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
  • B1B89-31 (50) Seat slide motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
  • B1B91-31 (50) Seat tilt motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
  • B1B93-31 (50) Seat recline motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
  • U0142-00 (50) Lost communication with body control module B
  • U0155-00 (50) LCD Gauge Communication Lost
FEM-Navigation
  • B100F-25 (50) Video input B - General signal failure - signal shape/waveform failure
  • B1010-25 (50) Video input C - General signal failure - signal shape/waveform failure
  • U2101-4A (50) Control module configuration incompatible - System internal failure - incorrect component installed
HCM-Headlamp
  • U0102-00 (50) Lost communication with transfer case control module
  • U0403-00 (50) Invalid data received from transfer case control module
HVAC-Ventilation
  • B1081-00 (50) Left temperature damper motor
  • B1081-49 (50) Left temperature damper motor - System internal failure - internal electronic failure
  • B1082-00 (50) Right temperature damper motor
  • B1082-49 (50) Right temperature damper motor - System internal failure - internal electronic failure
  • B1086-00 (50) Air distribution damper motor
  • B1086-49 (50) Air distribution damper motor - System internal failure - internal electronic failure
  • B1088-88 (50) LIN bus B - Bus signal/message failure - bus is off
  • B12B2-11 (50) Auxiliary heater coolant diverter valve - General electrical failure - circuit short to ground
  • B1A60-11 (50) Pollution sensor - General electrical failure - circuit short to ground
  • B1A69-11 (50) Humidity sensor circuit - General electrical failure - circuit short to ground
  • B1A69-15 (50) Humidity sensor circuit - General electrical failure - circuit short to battery or open
  • B1B62-11 (50) Pollution sensor nitrous oxide (NOX) input circuit - General electrical failure - circuit short to ground
  • B1B7B-00 (50) Air blend actuator - Rear left
  • B1B7B-49 (50) Air blend actuator - Rear left - System internal failure - internal electronic failure
  • B1B7D-00 (50) Air distribution actuator - Rear
  • B1B7D-49 (50) Air distribution actuator - Rear - System internal failure - internal electronic failure
  • B1B81-11 (50) Rear evaporator temperature sensor - General electrical failure - circuit short to ground
  • B1B81-15 (50) Rear evaporator temperature sensor - General electrical failure - circuit short to battery or open
  • B1C0A-88 (50) Control panel - Rear - Bus signal/message failure - bus is off
  • U0166-87 (50) Lost communication with auxiliary heater control module - Bus signal/message failure - missing a message
  • U0425-86 (50) Invalid data received from the auxiliary heater control module - Bus signal/message failure - signal is invalid
  • U3000-87 (50) Control module - Bus signal/message failure - missing a message
IPC-Instrument Pack
  • P0607-4B (50) Control module performance - System internal failure - over temperature
  • B1009-51 (50) Ignition authorisation - System programming failure - not programmed
  • B1009-87 (50) Ignition authorisation - Bus signal/message failure - missing a message
  • B100D-64 (50) Column lock authorisation - Algorithm based failure - signal plausibility failure
  • B1026-12 (50) Steering column lock - General electrical failure - circuit short to battery
  • B10B7-86 (50) Rear air discharge temperature - Bus signal/message failure - signal is invalid
  • B1A14-96 (50) Network management communication initialization - Component failure - internal failure
  • U0010-88 (50) Medium speed CAN communication bus - Bus signal/message failure - bus is off
  • U0100-00 (50) Lost communication with engine control module/powertrain control module 'A'
  • U0101-00 (50) Lost communication with transmission control module
  • U0121-00 (50) Lost communication with ABS control module
  • U0128-00 (50) Lost communication with parking brake control module
  • U0138-00 (50) Lost communication with all terrain control module
  • U0139-00 (50) Lost communication with the suspension control module B
  • U0151-00 (50) Lost communication with restraints control module
  • U0164-00 (50) Lost communication with heating ventilation and air conditioning control module
  • U0214-00 (50) Lost communication with the remote function actuation
  • U2013-08 (50) Switchpack - General failure information - bus signal/message failure
  • U3000-46 (50) Control module - System internal failure - calibration/parameter memory failure
  • U3000-49 (50) Control module - System internal failure - internal electronic failure
KVM-Keyless
  • B10C2-00 (50) Rear left unlock pull switch
  • B10C3-00 (50) Front right unlock pull switch
  • B10C4-00 (50) Rear right unlock pull switch
  • B10C9-00 (50) Interior front antenna
  • B10C8-00 (50) Interior center antenna
  • B10C7-00 (50) Interior luggage compartment antenna
  • B10C6-00 (50) Exterior luggage compartment antenna
  • B1336-00 (50) Front left door external antenna
  • B10CA-00 (50) Rear left door handle antenna
  • B1337-00 (50) Front right door external antenna
  • B10CB-00 (50) Rear right door handle antenna
  • C1017-00 (50) Boot/trunk primary switch
  • U0010-00 (50) Medium speed CAN communication bus
  • U201F-00 (50) External receiver
  • U2101-00 (50) Control module configuration incompatible
  • B12EA-00 (50) Radio frequency receiver
PAM-Parking Aid
  • B1B36-01 (50) Front right outer sensor - General failure information - general electrical failure
  • B1B36-12 (50) Front right outer sensor - General electrical failure - circuit short to battery
  • B1B36-96 (50) Front right outer sensor - Component failure - internal failure
  • B1B38-01 (50) Front right inner sensor - General failure information - general electrical failure
  • B1B38-12 (50) Front right inner sensor - General electrical failure - circuit short to battery
  • B1B38-96 (50) Front right inner sensor - Component failure - internal failure
  • B1B40-01 (50) Front left outer sensor - General failure information - general electrical failure
  • B1B40-12 (50) Front left outer sensor - General electrical failure - circuit short to battery
  • B1B40-96 (50) Front left outer sensor - Component failure - internal failure
  • B1B42-01 (50) Front left inner sensor - General failure information - general electrical failure
  • B1B42-12 (50) Front left inner sensor - General electrical failure - circuit short to battery
  • B1B42-96 (50) Front left inner sensor - Component failure - internal failure
  • B1B44-01 (50) Rear right outer sensor - General failure information - general electrical failure
  • B1B44-12 (50) Rear right outer sensor - General electrical failure - circuit short to battery
  • B1B44-96 (50) Rear right outer sensor - Component failure - internal failure
  • B1B46-01 (50) Rear right inner sensor - General failure information - general electrical failure
  • B1B46-12 (50) Rear right inner sensor - General electrical failure - circuit short to battery
  • B1B46-96 (50) Rear right inner sensor - Component failure - internal failure
  • B1B48-01 (50) Rear left outer sensor - General failure information - general electrical failure
  • B1B48-12 (50) Rear left outer sensor - General electrical failure - circuit short to battery
  • B1B48-96 (50) Rear left outer sensor - Component failure - internal failure
  • B1B50-01 (50) Rear left inner sensor - General failure information - general electrical failure
  • B1B50-12 (50) Rear left inner sensor - General electrical failure - circuit short to battery
  • B1B50-96 (50) Rear left inner sensor - Component failure - internal failure
  • B1B54-11 (50) Function LED - General electrical failure - circuit short to ground
PCM-Engine Petrol
  • P169F-00 (50) Control module - Unused fault code
  • P2300-11 (50) Ignition coil A primary control - circuit low - General electrical failure - circuit short to ground
  • P2303-11 (50) Ignition coil B primary control - circuit low - General electrical failure - circuit short to ground
  • P2306-11 (50) Ignition coil C primary control - circuit low - General electrical failure - circuit short to ground
  • P2309-11 (50) Ignition coil D primary control - circuit low - General electrical failure - circuit short to ground
  • P2312-11 (50) Ignition coil E primary control - circuit low - General electrical failure - circuit short to ground
  • P2315-11 (50) Ignition coil F primary control - circuit low - General electrical failure - circuit short to ground
  • P2318-11 (50) Ignition coil G primary control - circuit low - General electrical failure - circuit short to ground
  • P2321-11 (50) Ignition coil H primary control - circuit low - General electrical failure - circuit short to ground
  • P0116-29 (50) Engine coolant temperature - circuit range/performance - General signal failure - signal is invalid
  • P010F-00 (50) Mass or volume air flow sensor A/B correlation
  • P0365-31 (50) Camshaft position sensor B circuit (bank 1) - Frequency modulation/pulse width modulation failure - no signal
  • P0390-31 (50) Camshaft position sensor B circuit (bank 2) - Frequency modulation/pulse width modulation failure - no signal
  • P2405-00 (50) Evaporative emission system leak detection pump sense - circuit low
  • P2404-29 (50) Evaporative emission system leak detection pump sense - circuit range/performance - General signal failure - signal is invalid
  • P2450-00 (50) Evaporative emission control system switching valve performance or stuck open
  • P2451-00 (50) Evaporative emission control system switching valve stuck closed
  • P0442-00 (50) Evaporative emission system leak detected (small leak)
  • P0456-00 (50) Evaporative emission system leak detected (very small leak)
  • P0448-00 (50) Evaporative emission system vent control - circuit shorted
  • P0191-00 (50) Fuel rail pressure sensor range/performance
  • P0634-4B (50) Powertrain control module/engine control module/transmission control module internal temperature too high - System internal failure - over temperature
  • P061B-00 (50) Internal control module torque calculation performance
  • P0578-00 (50) Speed control multi-function input A circuit is stuck
  • P0590-00 (50) Speed control multi-function input B - circuit stuck
  • P0120-24 (50) Throttle/pedal position sensor A circuit - General signal failure - signal stays high
  • P0120-23 (50) Throttle/pedal position sensor A circuit - General signal failure - signal stays low
  • P0120-38 (50) Throttle/pedal position sensor A circuit - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
  • P0220-24 (50) Throttle/pedal position sensor/switch B circuit - General signal failure - signal stays high
  • P0220-23 (50) Throttle/pedal position sensor/switch B circuit - General signal failure - signal stays low
  • P0220-00 (50) Throttle/pedal position sensor/switch B circuit
  • P0220-82 (50) Throttle/pedal position sensor/switch B circuit - Bus signal/message failure - alive/sequence counter is incorrect/not updated
  • P057B-87 (50) Brake pedal position sensor circuit range/performance - Bus signal/message failure - missing a message
  • P0504-64 (50) Brake switch A/B correlation - Algorithm based failure - signal plausibility failure
  • P0724-17 (50) Brake switch B - circuit high - General electrical failure - circuit voltage above threshold
  • P0572-17 (50) Brake switch A - circuit low - General electrical failure - circuit voltage above threshold
  • P0573-16 (50) Brake switch A - circuit high - General electrical failure - circuit voltage below threshold
  • P0504-00 (50) Brake switch A/B correlation
  • P0500-82 (50) Vehicle speed sensor A - Bus signal/message failure - alive/sequence counter is incorrect/not updated
  • P0500-81 (50) Vehicle speed sensor A - Bus signal/message failure - invalid serial data received
  • P0500-83 (50) Vehicle speed sensor A - Bus signal/message failure - value of signal protection calculation is incorrect
  • P0500-85 (50) Vehicle speed sensor A - Bus signal/message failure - signal is above allowable range
  • P0721-85 (50) Output shaft speed sensor - circuit range/performance - Bus signal/message failure - signal is above allowable range
  • P0721-86 (50) Output shaft speed sensor - circuit range/performance - Bus signal/message failure - signal is invalid
PDM-Passenger Door
  • B109C-11 (50) Front courtesy lamps - General electrical failure - circuit short to ground
  • B109C-15 (50) Front courtesy lamps - General electrical failure - circuit short to battery or open
  • B10EC-11 (50) Passenger's door double locking motor - General electrical failure - circuit short to ground
  • B10EC-15 (50) Passenger's door double locking motor - General electrical failure - circuit short to battery or open
  • B10EE-11 (50) Rear door passenger side double locking motor - General electrical failure - circuit short to ground
  • B10EE-15 (50) Rear door passenger side double locking motor - General electrical failure - circuit short to battery or open
  • B1109-11 (50) Passenger's door central locking motor - General electrical failure - circuit short to ground
  • B1109-15 (50) Passenger's door central locking motor - General electrical failure - circuit short to battery or open
  • B110B-11 (50) Rear door passenger side central locking motor - General electrical failure - circuit short to ground
  • B110B-15 (50) Rear door passenger side central locking motor - General electrical failure - circuit short to battery or open
  • B110D-11 (50) Rear door passenger side power child locking motor - General electrical failure - circuit short to ground
  • B110D-15 (50) Rear door passenger side power child locking motor - General electrical failure - circuit short to battery or open
  • B11B9-11 (50) Passenger blind spot warning indicator supply - General electrical failure - circuit short to ground
  • B11B9-15 (50) Passenger blind spot warning indicator supply - General electrical failure - circuit short to battery or open
  • B11D1-83 (50) Local interconnect network bus C - Bus signal/message failure - value of signal protection calculation is incorrect
  • B11D1-86 (50) Local interconnect network bus C - Bus signal/message failure - signal is invalid
  • B11F7-11 (50) Passenger folding mirror motor - General electrical failure - circuit short to ground
  • B11F7-15 (50) Passenger folding mirror motor - General electrical failure - circuit short to battery or open
  • B1C11-11 (50) Passenger's left/right mirror motor circuit - General electrical failure - circuit short to ground
RLM-Suspension
  • C1A34-01 (50) Rear right corner valve - General failure information - general electrical failure
  • C1A35-01 (50) Reservoir valve - General failure information - general electrical failure
  • C1A37-01 (50) Front cross-link valve - General failure information - general electrical failure
  • C1A38-01 (50) Rear cross-link valve - General failure information - general electrical failure
  • C1A36-01 (50) Exhaust valve - General failure information - general electrical failure
  • C1A24-67 (50) No temperature increase when compressor requested - Algorithm based failure - signal is incorrect after the event
  • C1A18-64 (50) Pressure increases too rapid when filling reservoir - Algorithm based failure - signal plausibility failure
  • C1A24-64 (50) No temperature increase when compressor requested - Algorithm based failure - signal plausibility failure
  • C1A29-92 (50) Switch activation too long - Component failure - performance or incorrect operation
  • C1A30-64 (50) Both switches pressed at the same time - Algorithm based failure - signal plausibility failure
  • C1A03-26 (50) Front left height sensor - General signal failure - signal rate of change is below the threshold
  • C1A03-92 (50) Front left height sensor - Component failure - performance or incorrect operation
  • C1A04-26 (50) Front right height sensor - General signal failure - signal rate of change is below the threshold
  • C1A04-92 (50) Front right height sensor - Component failure - performance or incorrect operation
  • C1A05-26 (50) Rear left height sensor - General signal failure - signal rate of change is below the threshold
  • C1A05-92 (50) Rear left height sensor - Component failure - performance or incorrect operation
  • C1A06-26 (50) Rear right height sensor - General signal failure - signal rate of change is below the threshold
  • U0073-88 (50) Control module communication bus off - Bus signal/message failure - bus is off
  • C1A06-92 (50) Rear right height sensor - Component failure - performance or incorrect operation
  • C1A07-62 (50) Cross articulation - Algorithm based failure - signal compare failure
  • U3000-1D (50) Control module - General electrical failure - circuit current out of range
  • C1A20-64 (50) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
  • U0136-00 (50) Lost communication with differential control module - rear
  • U2000-67 (50) Motor temperature - Algorithm based failure - signal is incorrect after the event
  • U2007-67 (50) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event
  • C1130-7A (50) Air spring air supply - Mechanical failure - fluid leak or seal failure
  • C1138-23 (50) Access switch - General signal failure - signal stays low
SASM-Steering Angle
  • U1A14-49 (50) CAN initialisation failure - System internal failure - internal electronic failure
  • U0300-55 (50) Internal control module software incompatibility - System programming failure - is not configured
  • C0051-64 (50) Steering wheel position sensor - Algorithm based failure - signal plausibility failure
  • U3002-62 (50) Vehicle identification number - Algorithm based failure - signal compare failure
SRM-Satellite Radio
  • B1D79-84 (50) Microphone input - Bus signal/message failure - signal is below allowable range
  • U3000-56 (50) Control module - System programming failure - Invalid / incompatible configuration
  • B1A00-44 (50) Control module - System internal failure - data memory failure
  • B1A00-45 (50) Control module - System internal failure - program memory failure
  • U201A-54 (50) Control module main calibration data - System programming failure - missing calibration
  • U3000-54 (50) Control module - System programming failure - missing calibration
TCCM-Transfer Case
  • P0903-00 (50) Clutch actuator - circuit high
  • P0902-00 (50) Clutch actuator - circuit low
  • P0900-00 (50) Clutch actuator - circuit/open
TCM-Transmission 6spd
  • P0931-00 (50) Gearshift lock solenoid - circuit A high
  • P0562-21 (50) System voltage low - General signal failure - signal amplitude<minimum
  • P0561-1C (50) System voltage unstable - General electrical failure - circuit voltage out of range
  • P0219-86 (50) Engine overspeed condition - Bus signal/message failure - signal is invalid
  • P0717-12 (50) Turbine/input shaft speed sensor A circuit no signal - General electrical failure - circuit short to battery
  • P0716-14 (50) Turbine/input shaft speed sensor A - circuit range/performance - General electrical failure - circuit short to ground or open
  • P0716-22 (50) Turbine/input shaft speed sensor A - circuit range/performance - General signal failure - signal amplitude>maximum
  • P0716-21 (50) Turbine/input shaft speed sensor A - circuit range/performance - General signal failure - signal amplitude<minimum
  • P0721-64 (50) Output shaft speed sensor - circuit range/performance - Algorithm based failure - signal plausibility failure
  • P0721-27 (50) Output shaft speed sensor - circuit range/performance - General signal failure - signal rate of change is above the threshold
  • U3000-4B (50) Control module - System internal failure - over temperature
  • P0601-41 (50) Internal control module memory checksum error - System internal failure - general checksum failure
  • P062F-04 (50) Internal control module electrically erasable programmable read only memory error - General failure information - system internal failure
  • P0604-92 (50) Internal control module RAM error - Component failure - performance or incorrect operation
  • P0741-07 (50) Torque converter clutch solenoid - circuit performance or stuck off - General failure information - mechanical failure
  • U3001-94 (50) Control module improper shutdown - Component failure - unexpected operation
  • P0826-62 (50) Up and down switch input circuit - Algorithm based failure - signal compare failure
  • P0815-33 (50) Upshift switch circuit - Frequency modulation/pulse width modulation failure - signal low time>maximum
  • P0816-33 (50) Downshift switch circuit - Frequency modulation/pulse width modulation failure - signal low time>maximum
  • U0140-68 (50) Lost communication with body control module - Algorithm based failure - event information
  • U0422-66 (50) Invalid data received from the body control module - Algorithm based failure - signal has too many transitions/events
  • U0422-08 (50) Invalid data received from the body control module - General failure information - bus signal/message failure
  • P2700-07 (50) Transmission friction element A apply time range/performance - General failure information - mechanical failure
  • P2701-07 (50) Transmission friction element B apply time range/performance - General failure information - mechanical failure
  • P2702-07 (50) Transmission friction element C apply time range/performance - General failure information - mechanical failure
  • P2703-07 (50) Transmission friction element D apply time range/performance - General failure information - mechanical failure
  • P2704-07 (50) Transmission friction element E apply time range/performance - General failure information - mechanical failure
  • P0781-07 (50) 1-2 shift - General failure information - mechanical failure
  • P0782-07 (50) 2-3 shift - General failure information - mechanical failure
  • P0783-07 (50) 3-4 shift - General failure information - mechanical failure
  • P0784-07 (50) 4-5 shift - General failure information - mechanical failure
  • P0829-07 (50) 5-6 shift - General failure information - mechanical failure
  • P0829-77 (50) 5-6 shift - Mechanical failure - commanded position is not reachable
  • P0784-77 (50) 4-5 shift - Mechanical failure - commanded position is not reachable
  • P0783-77 (50) 3-4 shift - Mechanical failure - commanded position is not reachable
  • P0782-77 (50) 2-3 shift - Mechanical failure - commanded position is not reachable
  • P0781-77 (50) 1-2 shift - Mechanical failure - commanded position is not reachable
  • P0731-07 (50) Gear 1 incorrect ratio - General failure information - mechanical failure
  • P0732-07 (50) Gear 2 incorrect ratio - General failure information - mechanical failure
  • P0733-07 (50) Gear 3 incorrect ratio - General failure information - mechanical failure
  • P0734-07 (50) Gear 4 incorrect ratio - General failure information - mechanical failure
  • P0735-07 (50) Gear 5 incorrect ratio - General failure information - mechanical failure
  • P0729-07 (50) Gear 6 incorrect ratio - General failure information - mechanical failure
  • P0736-07 (50) Reverse incorrect ratio - General failure information - mechanical failure
  • P0121-86 (50) Throttle/pedal position sensor A - circuit range/performance - Bus signal/message failure - signal is invalid
  • P1706-9A (50) High vehicle speed observed in park - Component failure - Component or system operating conditions
TEL-Cell Phone
1 - 1 of 1 Posts
