1 - 6 of 6 Posts
I noticed a leak underneath my 2012 Range Rover Sport HSE today.
There was fluid on the driveway and the vehicle will not go in reverse. See attached photos. When I shift to reverse, the dash indicator still shows neutral. It will however shift to drive. The warning indicator indicates transmission service issue.
I am in visiting in a rural area with no Land Rover service close by.
Any suggestions/ideas?
Thanks!
wjsj69
I don't believe you have a dipstick, there are drain (lower) and fill (upper) plugs somewhere on the trans., and you might have to remove a skid plate to get to them. I'm sorry I cant direct you right to it, as I'm not familiar with your model. Try a search or find a shop manual. When you find the fill hole, remove the plug (usually an allen-head) and just stick a finger in and make sure the fluid is right up to the bottom of the hole. If not, you'll need a hand pump from an auto-supply, that will attach to a quart of atf, and pump it in until it comes out. Check your manual or do a search for the correct fluid and procedure. In this process, you might find the leak too. Good luck.
1 - 6 of 6 Posts
