1 - 3 of 3 Posts
My air or heater will not work together. It is either one or the other.
I found information on the web on hitting the start only, turn off air, start the car and the heater works.
same thing, start only, turn on air and the air works. It will not switch from the heater and air.
When the heater is on, it gets so hot it actually turned off the control panel and you cannot touch the vents.
I cannot find anything to fix this.
Thanks
The control panel is straight forward on turning on your heater and air. This is either hot as heck with no temperature setting or air conditioning.
This started when I moved from sea level to 7000 ft level if that matters.
I have either one, not both. I have had this car for 5 years.
Thank for the re[ly
1 - 3 of 3 Posts
