1 - 1 of 1 Posts
Ok, I am in the process of doing a ton of work to my 94 D1 3.9. I dropped the pan and cleaned out the GOBS of slusge and carbon fromthe pan and pickup. I have a new oil pump, but just wanted to verify how to change it.
I would assume.....
1. Remove the Serp. Belt
2. remove front cover
(does the water pump need to come off? What about the distributor?)
3. swap out pump
4. Re-install everything
Has anyone here ever stretched out the spring for a bit more PSI?
Thanks.....
1 - 1 of 1 Posts
