1 - 2 of 2 Posts
Follow the sticky in the D2 section. Replace the switch pack. If the unit is leaking you can try shuttle valve seals, or just replace the unit. There are no shortages of used one's. The unit does not require removal for the first repair.
You should also consider the "Option 2" mod which eliminates a problematic connection.
1 - 2 of 2 Posts
