1 - 3 of 3 Posts
Hello all
I have a 2000 discovery with 156k miles now and recently I have noticed that my truck will sometimes delay the 4th gear shift until im going 50+ at 3200 RPM. It only does this with the 4th gear and it doesn't always behave in the same manor. It seams that if i drive it more then 20 minutes or if im driving it a little harder then normal it will have this issue. I have also noticed the shift from 3rd to 4th under acceleration is not always a smooth one.
I should also mention that I replaced the ATF some time last year. however i did not replace the filter.
Do you have a service engine light on, if so what are the fault code numbers. Have you checked your fluid level and color is it bright red or brownish?
1 - 3 of 3 Posts
