Paul thanks for the reply. It seems that a lot of people have the instrument bezel issues. On a side note, do you have the right front and rear left window motors? If you do and they work how much would you want for the two? What about cup pods, I'm looking for two black ones. Thanks again.
The problem with the bezel boils down to people being to aggressive when they remove the part from the dash. This one was just resting on top of the instrument binnacle. I can appreciate the plastic around the screws giving way over time but the two upper clips are fine when you lift the bezel up and towards you as you take it out. I had to teach every guy I've had work with me how to remove this silly part.
Now, as far as the window motors, I do have them in stock. Do you also need the regulators as well? The rear motors on the last few years of the DII were connected directly at the motor rather than with an interconnect five or six inches down the wiring harness. I'll PM you the cost of the motors with and without the regulators.
I do have the black cup holders with inserts and mounting hardware. The only problem is that the clips on the upper portion of the cup holders are broken on both. That means that you can't secure the upper portion to the bottom as securely. A dab of glue would solve that problem but I'm going to leave that up to whomever buys these. If you want them you can have them for $40 including shipping. Otherwise, I'll probably post them on eBay shortly.
Cheers,
Paul
